Guest ljluki Posted January 17, 2007 Share Posted January 17, 2007 Hi, What's means B04D? it is from N/A auto in UK-spec What is diff ratio?? Thanks Link to comment Share on other sites More sharing options...
Alex Posted January 17, 2007 Share Posted January 17, 2007 There are no NA UK spec cars. And the code you mention doesn't exist either. AXLE Example Description Crown Wheel Size = A (8'' - 203mm), B (8.7'' - 221mm) Differential Ratio = 01 (4.083:1), 02 (3.769:1), 03 (3.267:1) Differential Type = A (Standard open differential), B (Torsen LSD) Link to comment Share on other sites More sharing options...
Guest ljluki Posted January 17, 2007 Share Posted January 17, 2007 thanks, I know...http://www.mkiv.co.nz/specs.htm but i saw this code on engine tag information. Maybe something about diff ratio?? Link to comment Share on other sites More sharing options...
Alex Posted January 17, 2007 Share Posted January 17, 2007 If it is I can't find any information... Have you got a photo you could attach? Link to comment Share on other sites More sharing options...
Guest ljluki Posted January 17, 2007 Share Posted January 17, 2007 thanks, Unluckily I haven't.... I would like to swap this LSD/ I hope that is torsen/ to my lexus sc 300TT/1jz-swaped/. Link to comment Share on other sites More sharing options...
bondango Posted January 17, 2007 Share Posted January 17, 2007 I take it this was from an Ebay seller? i would contact him before buying, the one i seen advertised on ebay was described as a UK TT Diff, but with that diff code - so if its the same seller he may have just made a mistake with the code. Link to comment Share on other sites More sharing options...
Guest ljluki Posted January 17, 2007 Share Posted January 17, 2007 It's quite possible that it's the same differential. This one is from ebay too. But the seller have N/A supra-broken. I think that code is correct beacause I saw this code in my friend's car a few years ago. It was N/A auto....Thanks for any suggestion especialy about diff ratio Link to comment Share on other sites More sharing options...
JohnK Posted January 17, 2007 Share Posted January 17, 2007 A UK TT diff should be easy to spot because of the oil cooler pipes. Link to comment Share on other sites More sharing options...
Guest ljluki Posted February 14, 2007 Share Posted February 14, 2007 hi, i know... B-series diff ratio 3,54 torsen with cooler Link to comment Share on other sites More sharing options...
