lackie Posted June 14, 2004 Share Posted June 14, 2004 got my c wilson pipes fitted, but cannot feel any significant changes. could i maybe have a problem??? the exhaust is a little louder but not much, i have an abflug back box, but i have two pipes coming out from the back to the decat pipes. really am worried as i was expecting some serious power gains any help advice welcome cheers lack Link to comment Share on other sites More sharing options...
BigRoy Posted June 14, 2004 Share Posted June 14, 2004 UK or Jap? U need a boost controller or bleed valve on a UK. Link to comment Share on other sites More sharing options...
mr keef Posted June 14, 2004 Share Posted June 14, 2004 Hey mate , before i got mine fitted i was running standard boost,after they were fitted i was running 14 psi so thats how i noticed the power,if i started running standard boost again im not sure if it would have felt any different than before the decat,mabye just a little more responsive at low revs,i wish i had of just turned the boost up and left the cats on now for all the mot reasons. IMO:) Link to comment Share on other sites More sharing options...
lackie Posted June 14, 2004 Author Share Posted June 14, 2004 im j spec, i havent fitted my fcd yet could that be a problem???? i have a friendly mot tester, my best mate hehe even when i got the car coming from a mighty 1.6 focus zetec i still didnt fell any great power, maybe i was expecting to much, gonna get it on the rolling road asap to find out if there are any issues. but i really dont like this, as i said was expecting to see some sort of change, but absolutley nothing. i have a mines ecu?????? so a boost controller and probably a nur spec should do the trick eh how do u tell the psi?? rolling road??? lack Link to comment Share on other sites More sharing options...
BigRoy Posted June 14, 2004 Share Posted June 14, 2004 FCD would only help if your hitting the limiter. First thing to do is to fit a boost gauge and see what your hitting psi wise. Link to comment Share on other sites More sharing options...
lackie Posted June 14, 2004 Author Share Posted June 14, 2004 i have a greedy boost gauge thingy that tells me im hitting 1.1 bar but before i got the pipes fitted i was hitting 1.2 bar Link to comment Share on other sites More sharing options...
Jake Posted June 14, 2004 Share Posted June 14, 2004 Originally posted by lackie i have a greedy boost gauge thingy that tells me im hitting 1.1 bar but before i got the pipes fitted i was hitting 1.2 bar That doesn't make sense! You're making LESS boost after removing the Cats? WTF? Link to comment Share on other sites More sharing options...
Barney Posted June 14, 2004 Share Posted June 14, 2004 Pick up is (or a least, it should be) a lot better due to turbo's spooling up a lot quicker. As a comparrison if you can, try blagging a ride in a similar spec Soop to yours, as IMHO you should notice a difference going from catted to de-catted. Link to comment Share on other sites More sharing options...
lackie Posted June 14, 2004 Author Share Posted June 14, 2004 i know worrying has become a mind set over the past week i took her out last night and really gave it some wellie, got to 160/165 and was only reading 1.1 on the gauge with my red warning light on i think i'll borrow the 60 bucks and get it on the rolling road asap lack Link to comment Share on other sites More sharing options...
BigRoy Posted June 14, 2004 Share Posted June 14, 2004 What was the ambient temp difference between the 1.2 with cats and the 1.1 without? Is it much warmer now? Could be charge cooling? Whats your intercooler like? Link to comment Share on other sites More sharing options...
lackie Posted June 14, 2004 Author Share Posted June 14, 2004 i dont know how to tell this, but the intercooler does smell a bit after a long run??? Link to comment Share on other sites More sharing options...
outatime Posted June 14, 2004 Share Posted June 14, 2004 Originally posted by lackie i dont know how to tell this, but the intercooler does smell a bit after a long run??? Just have a look, my old one was crumbling to pieces with fins missing everywhere. If yours is an older j-spec, chances are the i/c is past its best. Link to comment Share on other sites More sharing options...
lackie Posted June 14, 2004 Author Share Posted June 14, 2004 its a 93l and its a front mount i/c and looks to be in good to decent condition, no expert tho, but would consider its been on not to long before imported. Link to comment Share on other sites More sharing options...
outatime Posted June 14, 2004 Share Posted June 14, 2004 I assumed you were still using the stock i/c, if you have an FMIC you should be ok as far as charge temps go. Link to comment Share on other sites More sharing options...
trooper Posted June 14, 2004 Share Posted June 14, 2004 Did you take out both cats or just the second one? I believe that removing the second cat will only add about 10BHP which is not significant. The benefit should be felt on throttle response though. Link to comment Share on other sites More sharing options...
lackie Posted June 14, 2004 Author Share Posted June 14, 2004 i replaced both cats, to be honest i really think my exhaust is very restictive. its 5" wide and seems to be straight through apart from it spliting into two pipes then coming together to fit to the c wilson pipes but i cant think of anything else:conf: Link to comment Share on other sites More sharing options...
eyefi Posted June 14, 2004 Share Posted June 14, 2004 u wont feel any performance increase if u where running 1.2 bar before decat except a slightly less lag. a supra at 1.2 bar will feel a hell of a lot different to a focus, sounds like u have a problem somewhere. r u sure u had some cats on before? what red warning light did u have on? Link to comment Share on other sites More sharing options...
lackie Posted June 14, 2004 Author Share Posted June 14, 2004 i certainly thought the soop was a hell of a lot faster just wasnt blown away by it if you know what i mean. yeah i had the cats in got em in my shed and they weigh a fcuk'ing ton. im gonna get it on the rolling road asap, i'll post up the results when i get em cheers for the advice etc lack Link to comment Share on other sites More sharing options...
