Barnstormer Posted June 10, 2004 Share Posted June 10, 2004 Just had someone bash my left bumper in Tesco's the other day and now need a new lens and gasket. Its on the LH bumper on my facelifted 97 j-spec. see below if anyone can help with some q's I'd appreciate it. 1. What is the part no. for the lens and gasket? 2. Is it the same as for a UK spec? My local Toyota dealer isn't too good with j-spec stuff... 3. How do you get the lens off? Is it pull off or is there some bolts on the inside of the wing? The bulb assembly is still intact and works OK. Link to comment Share on other sites More sharing options...
Barnstormer Posted June 10, 2004 Author Share Posted June 10, 2004 and another pic... Link to comment Share on other sites More sharing options...
Timwildman Posted June 10, 2004 Share Posted June 10, 2004 1, Not sure but it's acomplete assembly. (Should be cheap the back ones are only a few pounds) 2, not fitted to uk model. 3, undo some nuts on the other side of the wing, you'll need to remover the wheel arch liner to get to it. Link to comment Share on other sites More sharing options...
Barnstormer Posted June 10, 2004 Author Share Posted June 10, 2004 thanks for the info. Called the local Toyota parts guy who is normally useless and found that he'd been replaced by a new man who has a Supra! Anyway, he reckons he can get me a complete new assembly for £15 +vat by Sat. hopefully the fitting won't be too difficult. ATB Link to comment Share on other sites More sharing options...
