Chris and Alana Posted January 4, 2007 Share Posted January 4, 2007 Will a j-spec soop boost to 1.0 bar with the second cat left in (with a perfermance exhaust aswel)? I know the first cat is alot more restrictive so if I keep the second will I still be able to reach 1.0bar? I know alot of you will recomend a full decat but I dont want to boost 1.2 bar just 1.0 bar and if it will do this with the second cat left in, it should also pass MOT and keep the noise of the exhaust down a bit. Iv heard they are really loud fully decatted. Link to comment Share on other sites More sharing options...
Chris and Alana Posted January 4, 2007 Author Share Posted January 4, 2007 I know this must be talked to death and im sorry but I just cant find the answer through the 'search' facility Please me Link to comment Share on other sites More sharing options...
R Black Posted January 4, 2007 Share Posted January 4, 2007 I'm curious on this one too, although i think i read somewhere that this set up would punish the 2nd cat. Link to comment Share on other sites More sharing options...
wkdtime Posted January 4, 2007 Share Posted January 4, 2007 It depends on your car, each car is different, but generally, Ist cat taken out and second cat left in with a free flowing exhasut should see you 1.0Bar easily. Link to comment Share on other sites More sharing options...
Chris and Alana Posted January 4, 2007 Author Share Posted January 4, 2007 I'm curious on this one too, although i think i read somewhere that this set up would punish the 2nd cat. I dont think leaving the second cat in does any harm. I think if you leave the first cat in and up the boost with a EBC for example the restriction of the cat will cause very high EGT's and put alot of stres on the turbos. But as far as I know the second cat is less restrictive and further away from the turbos so at 1.0bar EGT's should be fine but I dont know if the restriction will be little enough to allow the turbos to create a natural 1.0 bar boost, thats why I'v started this thread. (I hope Im right with everything there) Link to comment Share on other sites More sharing options...
R Black Posted January 4, 2007 Share Posted January 4, 2007 You may well be correct, i hope you are, as i want to run this way to start too, for a while anyways, but from what i read was it(2nd cat) would run a lot hotter than it should. Link to comment Share on other sites More sharing options...
Steviekid Posted January 4, 2007 Share Posted January 4, 2007 but I dont know if the restriction will be little enough to allow the turbos to create a natural 1.0 bar boost, If your car doesn't run 1.0bar with that setup then you can easily stick an EBC/MBC in to up it to that. Link to comment Share on other sites More sharing options...
Chris and Alana Posted January 4, 2007 Author Share Posted January 4, 2007 If your car doesn't run 1.0bar with that setup then you can easily stick an EBC/MBC in to up it to that. Thats abit expensive to do it that way. Im going to try it at the end of the month (first decat that is) and see what happens. If it doesnt reach 1.0bar I think Il take the second cat out aswel and put a 1.0bar rr in. that should sort it. It would just be nice if I could keep the second cat in and reach that boost level as it keeps it legal and keeps the exhaust noise down a bit aswell as give me more power:eyebrows: If anyone has this set up it would be nice to know what boost you are making Link to comment Share on other sites More sharing options...
Steviekid Posted January 4, 2007 Share Posted January 4, 2007 Thats abit expensive to do it that way. MBC's are about £20 Link to comment Share on other sites More sharing options...
Chris and Alana Posted January 5, 2007 Author Share Posted January 5, 2007 MBC's are about £20 Sorry, I read the post to quick and forgot I could use a MBC. I suppose I could do it that way aswel. never thought of that, thank's Link to comment Share on other sites More sharing options...
jaymdee Posted January 5, 2007 Share Posted January 5, 2007 Hi, I've got the first cat replaced and second cat still fitted. I get 1.0Bar nicely. EGTs (manifold) usually around 850, but have hit 900 on extended blast at WOT. In the summer only saw about 0.9-0.95Bar. J Link to comment Share on other sites More sharing options...
Chris and Alana Posted January 5, 2007 Author Share Posted January 5, 2007 Hi, I've got the first cat replaced and second cat still fitted. I get 1.0Bar nicely. EGTs (manifold) usually around 850, but have hit 900 on extended blast at WOT. In the summer only saw about 0.9-0.95Bar. J Thanks very much, just what I was looking for:) Did you find a difference in performance at 1.0 bar with the second cat left in (over stock)? Link to comment Share on other sites More sharing options...
jaymdee Posted January 5, 2007 Share Posted January 5, 2007 Definately more pull when 2nd turbo comes online - much more kick. Also spools up quicker and easier. Not as punchy as 1.2Bar, but easier for MOT time and not so much strain on turbos etc. I've also got a Greddy 2-row FMIC, which I think helps keep temps more down, which means power too Link to comment Share on other sites More sharing options...
Rico2006 Posted January 5, 2007 Share Posted January 5, 2007 I didnt notice much of a noise increase when I decatted, however, the NurSpec-R is a noisy beast anyway. You only ever have a problem at MOT time, and a quick pint for the hard working garage owner soon sorts that little problem out. Boost is a funny game, im decatted, with a 1bar RR, but still manage to hit 1.2 bar on the cold days. Jaymdee - the FMIC cools the inbound air charge, not the EGTS so although the FMIC helps maintain the power you have it's not really relevent to the EGTvs Cat issue. Link to comment Share on other sites More sharing options...
jaymdee Posted January 5, 2007 Share Posted January 5, 2007 Jaymdee - the FMIC cools the inbound air charge, not the EGTS so although the FMIC helps maintain the power you have it's not really relevent to the EGTvs Cat issue. I know mate, hence the comment on increasing power. I mentioned it as I really noticed the difference vs stock and wanted to make it clear that the effect could be down to 1st Cat AND FMIC. Link to comment Share on other sites More sharing options...
BASHTHEBISHOP Posted January 6, 2007 Share Posted January 6, 2007 I am interested in this post to:- I have a jspec, 2nd decat, blitz nur spec exhaust and FCD. Will i still get just standard boost? 0.7ish? Or am i at risk of over boosting? If i want to boost to 1bar do i need a MCB or do i need 1st decat as well? Any hep appreciated. Thanks. Link to comment Share on other sites More sharing options...
Chris and Alana Posted January 6, 2007 Author Share Posted January 6, 2007 well Im not the best at this either but from what Ive read the first cat is the more restrictive than the second. restrictive enough to allow the wastegate to do its proper job (keep boost down) I think from other threads you 'may' get a slight increase of a couple PSI or 0.1 bar with the first cat left in. Buy a boost gauge, that will answer your question straight away. I bought a cheap autogauge one of ebay for £18 and it works fine, easy to install, just take the clock out (for a 52mm gauge and it fits perfect. or the air vent for a 60mm. its worth the small amount of notes just so you know what your boosting. Anyway thats the limit of my knowledge, hope it helps Link to comment Share on other sites More sharing options...
R Black Posted January 7, 2007 Share Posted January 7, 2007 Also it varies from car to car, how much you get from set mods, but i agree your unlikely to hit one bar with a 2nd decat, & blitz NUR, but a boost gauge is the way to go for piece of mind. Link to comment Share on other sites More sharing options...
