heating
Guest blownbytwins
Guest blownbytwins
hi guys,ive recently changed the coolent on the supe i used the toyota stuff but it doesnt seem to get very warm inside it woz fine b4 i changed it,its not overheatin and its drivin fine,any ideas wot it could be,should i rebleed it again?wots the best way to bleed the supe?
When the engine is cold.
Pull off the top heater hose which is at the rear of the engine and fill with coolant, do this slowly to avoid trapping air.
Fill the resevoir to the full line.
You should always have your heater on max temp to allow coolant to flow into the heater when whilst renewing the coolant.
