Tubo 1 working ?
markjodrell
hope someone can help.:(
just got my TT, I am worried that the first turbo may not be boosting as I cannot hear any whistle at all when reving up.
When I rev to 4k the whistle is there then.
I thought you should hear the 1st turbo whistle at around 1500 revs.
Any way of checking this out.
getting quite concerned
1996 tt pre facelift 43k
any comments appreciated:( :(
Yeh unless youve got a really loud exhaust. The wistle is audible about 1.5k upwards. Open the window and drive and its noticeable to yourself also to pedestrians.
If you set off pretty sharpish from a standstill up to about 30mph and then let of the gas the stock bov will whoosh, how quick does the car feel it should feel very quick low down, very responsive!? Loads of low down torque with that turbo being so early.
Maybe your turbos are set to run in parallel instead of in secuence? As it can be changed but not sure what the difference feels like?
hi again m8,
just been outside again,
had the bonnet up , if I hit the accelerator hard and release at just under 3k revs I can hear the stock bov, a obvious hiss, is this going to be the first turbo or the second turbo.
Re the power , since Ive had it all its done is throw it down so I have not been able to do a really fast start, although I did have the back end twich out on a round about on very moderate throttle.
It seemed to go pretty well but ive never driven or been in a tt before so have nothing to compare it to
without the first turbo would it be REALLY sluggish?
First turbo for sure, sounds like its boosting to me then as it wudnt do that i dont think if the 1st turbo was shot as far as i know anyway.
Sounds like its all normal to me but you really need to get a boost gauge to confirm really.
well yeh in comparison but if youve not driven the tt before its hard to tell isnt it as it would still be quick.
I think they show 0.4 from the first turbo and 0.8/9 from the second turbo, foot obviously flat to floor! When it shows 0.8 both turbos are online i think.
But you should able to see it boostin even just touching the throttle as the guage starts in negative figures. Give it a dab of the throttle and youll see the gauge move into positive boost pressure.
Rayman
thank for your help and you patience
much appreciated, just hope all is well as it could be an expensive job.
I suppose if the roads are dryish 2morrow I could try a 0-60 time and if its 6 secs or below both turbos are working, would you say that would be a reasonable test ??
Rayman
Yeh absolutley, autos are a little sluggish off the line but once you get off the line it should take off and pull you back hard in your seat. You should here the turbo sounding straight away and then over 4K revs the straight 6 starts to sing and drowns out the turbos! If you not used to big bhp cars like me it feels like a rocket ship basically, scary at first Lol:p ! What was your previous car?
hi Mark If you get scared its working!
sounds OK to me with stock air box ? your not going to hear much from 1 tubby anyhow; 2 comes on line at 4000 and there should be a noticeable power surge then. I have oem filter apexi fitted so mine roars a lot but does whislt when accelerating
Rich
Rich
:iagree: although there is a noticeable power surge at 4K i find the initial push from low down more exilahrating if thats the right word to use!:D
rayman and fifty
and the rest who took the time to answer
BIG thanks again for the comments and advise
well appreciated
Mark
ps will let you all know the outcome sooooooon:blink:
Ok let us know the outcome and pay your membership, best tenner ever spent!:D
just got in from the garage, one worry sorted another found.
the turbos are just fine , but now I need my ears testing as the whistle was there all the time, it my age you know.
thanks for the help, i have now posted another query , may you can help with this one.
mark
