DamanC Posted December 3, 2006 Share Posted December 3, 2006 Hi guys, im in the middle of replaceing my auto knob but have reached a dead end. The knob is off apart from the overdrive button and wire that still runds throught the knob. How do i get this out........cut the wires and rejoin? Cheers Link to comment Share on other sites More sharing options...
jamesmark Posted December 3, 2006 Share Posted December 3, 2006 Cut and rejoin thats what i done, crimped on connectors so I could easily take them apart again, used aditional wire too Link to comment Share on other sites More sharing options...
DamanC Posted December 3, 2006 Author Share Posted December 3, 2006 Thanks buddy Link to comment Share on other sites More sharing options...
jamesmark Posted December 3, 2006 Share Posted December 3, 2006 No Probs. I have to ask if not asked before but why the advert for head and shoulders? Link to comment Share on other sites More sharing options...
bungy Posted December 3, 2006 Share Posted December 3, 2006 How did you get it off in the first place as I can see no fixings and didn't think it screwed on. I really need to change mine. Did you get a new replacement and from where? Any help would be appreciated. Link to comment Share on other sites More sharing options...
DamanC Posted December 3, 2006 Author Share Posted December 3, 2006 Well i think its done, havent had chance to test my bodgeit and leggit ovrdrive rewireing but it should be ok. One thing that does concern me is for some strange reason i seem to have 12 bolts and a turbo left over James its just a play on the trader thing, i dont have a prefered trader so rather than being left out i made my own Bungy - I got mine of Nic aka import pimp from here. Under the actual knob is a sleave, slide it down to reveal 2 screws, remove. Around the buttons is a cover, this will prise off, unclip the overdrive button. You will see the 2 overdrive buttons where the sleave used to be, cut them and slide the over drive button out noting where the wires run. The knob will then lift off. The release button also needs to be reused, i wedged mine off with a screw driver but snapped half the holding mechanism, turns out this doesnt matter but it looks like to remove it you simply have to pull bloody hard. Then just reverse the process to refit the new one, its very fidderly and with no light took me about an hour or so. Hope this helps Link to comment Share on other sites More sharing options...
bungy Posted December 3, 2006 Share Posted December 3, 2006 Cheers i'll look into it right away as mine looks scruffy. Link to comment Share on other sites More sharing options...
Guest blueangel Posted December 3, 2006 Share Posted December 3, 2006 I retrimmed mine looks loads better and matches my dash now. Link to comment Share on other sites More sharing options...
gaz1 Posted December 3, 2006 Share Posted December 3, 2006 nic does a cracking levoc knob for the auto;) Link to comment Share on other sites More sharing options...
