Bonnet water jet blocked – how do I get to it?
V
One of the jets has got blocked on the bonnet, and looking on the under side of the bonnet it seems to be within the inner skin (I haven’t taken the insulation off yet)
Can the jet be clipped/twisted off externally so that I can give it a good clean, or can you get to it from under the bonnet, although it doesn’t seem likely as said above?
Many thanks
Stephen V
PS. had a bit of a posting spree:)
There's a black rubber plug, pull it off and you can use a small screwdriver to press in the two plastic lugs on the tube below the bonnet washer. This will allow the washer to be pulled out the top of the bonnet, with the rubber hose still attached.
All the above is done by "feel" alone.
I can't remember if you have to remove the bonnet liner to do this.
