Dave Haggas Posted November 10, 2006 Share Posted November 10, 2006 Had my uk spec on a ramp today and removed the plastic guard from under the engine.I replaced the oil filter and the oil.I drained the diff of oil and replenished.I then removed the bolts on the steering rack to replace the old mounting bushes.The bushes were replaced then I refitted the plastic guard.This is ALL I did. I drove approx 1 mile and then went to overtake a car,I put my foot down and the car lost all power!I tried the throttle and it was as if the cable had snapped.The car I was trying to overtake carried on and I had to get on the hard shoulder a bit lively!When I came to a halt the revs were going mad up and down,so I tried to keep it steady with the throttle ,which kept it from dying but would not rev at all?Just a VERY lumpy tick over.Decided to put it in drive and crawl off to the next exit.Tried the throttle and it did nothing.After about another mile it sort of cleared instantly and off it went!I have done about 20 miles since this occured today and since then it has ran perfect (as it has done since January when I bought it) It is very worrying.What could it be?I checked all hoses etc and all appears well.Any ideas guys? Link to comment Share on other sites More sharing options...
Fifty Posted November 10, 2006 Share Posted November 10, 2006 could it be ....yes it might be tara loose coil pack clip? Rich Link to comment Share on other sites More sharing options...
Dave Haggas Posted November 10, 2006 Author Share Posted November 10, 2006 could it be ....yes it might be tara loose coil pack clip? Rich What?If you are saying what I think,I cant imagine that this would prevent the car from reving? Link to comment Share on other sites More sharing options...
Fifty Posted November 10, 2006 Share Posted November 10, 2006 Dave it happens to me regularly ; full loss of power, no revs and terrible misfire - give em a wiggle (front 1 in my case) and shes OK again. Also happens usually on WOT just when Im overtaking:( Rich Link to comment Share on other sites More sharing options...
dangerous brain Posted November 10, 2006 Share Posted November 10, 2006 You can buy new clips to fix that AFAIK. The white insulator part inside cost about £11 I think. Link to comment Share on other sites More sharing options...
Fifty Posted November 10, 2006 Share Posted November 10, 2006 correct; thx but minestill does it with new clips WTF! Rich:D Link to comment Share on other sites More sharing options...
dangerous brain Posted November 10, 2006 Share Posted November 10, 2006 Borrow a set of coil packs and see if it still does it???? Link to comment Share on other sites More sharing options...
Dave Haggas Posted November 11, 2006 Author Share Posted November 11, 2006 Dave it happens to me regularly ; full loss of power, no revs and terrible misfire - give em a wiggle (front 1 in my case) and shes OK again. Also happens usually on WOT just when Im overtaking:( Rich I took out a second morgage 3 months ago to finance 6 new coil packs as an uneven tickover told me to do it!Also bought new coil pack connectors,have fitted one.Need to sort the rest soon.So I guess this must be a coincidence that it happened after me dicking about? Cheers guys..... Link to comment Share on other sites More sharing options...
dangerous brain Posted November 11, 2006 Share Posted November 11, 2006 I took out a second morgage 3 months ago to finance 6 new coil packs as an uneven tickover told me to do it!Also bought new coil pack connectors,have fitted one.Need to sort the rest soon.So I guess this must be a coincidence that it happened after me dicking about? Cheers guys..... Man I wish I knew that I have a full set sitting in a box in my garage in Dorset you could have borrowed. Link to comment Share on other sites More sharing options...
Dave Haggas Posted November 12, 2006 Author Share Posted November 12, 2006 Man I wish I knew that I have a full set sitting in a box in my garage in Dorset you could have borrowed. Thanks DB! I wish I had of known too...I see your location is Dorset,I travelled to chesil beach to pick the Supe up. Link to comment Share on other sites More sharing options...
