Lebsteif Posted November 6, 2006 Share Posted November 6, 2006 I want to assemble my rearspats. Can i use strong doublesided tape or do i have to glue them? I prefer tape if that is possible and which tape do you suggest? or can i use any kind of tape that is really strong? Link to comment Share on other sites More sharing options...
Lebsteif Posted November 7, 2006 Author Share Posted November 7, 2006 anyone? Link to comment Share on other sites More sharing options...
Ian W Posted November 7, 2006 Share Posted November 7, 2006 are they OEM or aftermarket ones? Link to comment Share on other sites More sharing options...
mikeyb10supra Posted November 7, 2006 Share Posted November 7, 2006 Tape will do fine....run a strip across the top as close to the lip as possible and bolt the bottom onto the rear Link to comment Share on other sites More sharing options...
Lebsteif Posted November 7, 2006 Author Share Posted November 7, 2006 are they OEM or aftermarket ones? Oem's Tape will do fine....run a strip across the top as close to the lip as possible and bolt the bottom onto the rear Ok, thanks i will do that Link to comment Share on other sites More sharing options...
CardiffSupra Posted November 7, 2006 Share Posted November 7, 2006 I used Tigger Seal, Pretty good apart from where i filled the gaps in with it and it turned a grey/black colour, not nice on a white car. Link to comment Share on other sites More sharing options...
Ian W Posted November 7, 2006 Share Posted November 7, 2006 if they're OEM then definitely use the tape as already suggested. it also makes them easier to remove should you ever want to do that. Link to comment Share on other sites More sharing options...
