Matt _Aero top_ Posted November 1, 2006 Share Posted November 1, 2006 Well as some of you might know i've got a problem with my sup . I've got a knocking on the front and can't seem to get it to stop . How do you tell if the drop links are nackered ? i was checking them out the other day and you can move them side to side piece of piss but not really much up and down movement which me thinks there shouldn't be ? Link to comment Share on other sites More sharing options...
Matt _Aero top_ Posted November 1, 2006 Author Share Posted November 1, 2006 Link to comment Share on other sites More sharing options...
JODY T Posted November 1, 2006 Share Posted November 1, 2006 It may be your lower arm knocking, Ive replaced so many of these for this type of problem its untrue! Link to comment Share on other sites More sharing options...
Matt _Aero top_ Posted November 1, 2006 Author Share Posted November 1, 2006 Lower arm with the ball joint ? how did you check this ? Link to comment Share on other sites More sharing options...
JODY T Posted November 1, 2006 Share Posted November 1, 2006 Its a hard one that... I usually try and find play by getting underneith the car and moving the wheels side to side whilst watching the 2 joints for movement.. It hard to recreate the knocking as you cant put the weight of the car on it to move it.. Does it knock when you turn or over bumps? Link to comment Share on other sites More sharing options...
Matt _Aero top_ Posted November 1, 2006 Author Share Posted November 1, 2006 It knocks like hell over bumps and sometimes when putting the car on the curb and turning at makes a cracking sound . even when driving on roads that arn't that bumpy you can feel it tremmering away . Link to comment Share on other sites More sharing options...
Guest dave-m Posted November 1, 2006 Share Posted November 1, 2006 had knocking from both sides on mine changed both struts that fixed the prob on mine Link to comment Share on other sites More sharing options...
Matt _Aero top_ Posted November 1, 2006 Author Share Posted November 1, 2006 The suspension struts ? Link to comment Share on other sites More sharing options...
Mike Posted November 1, 2006 Share Posted November 1, 2006 sub frame? Link to comment Share on other sites More sharing options...
Matt _Aero top_ Posted November 1, 2006 Author Share Posted November 1, 2006 Checked my subframe there all good or the ones i could see i did - 6x19mm and 4x17mm and all was tight Link to comment Share on other sites More sharing options...
