Conrad Posted October 30, 2006 Share Posted October 30, 2006 This keeps coming on and off at random times whilst I'm driving, I can't figure out what's causing it. Is this the warning light which tells me I need to check my codes? If so how do i do it? Link to comment Share on other sites More sharing options...
Dave Posted October 30, 2006 Share Posted October 30, 2006 check here m8 its a comman fault http://www.mkivsupra.net/vbb/showthread.php?t=39044normally the error code is the engine shaped light on the right hand top display this is what flashes to tell you whats wrong . Link to comment Share on other sites More sharing options...
Conrad Posted October 30, 2006 Author Share Posted October 30, 2006 Cheers Dave - appreciated. Link to comment Share on other sites More sharing options...
Todd Posted October 30, 2006 Share Posted October 30, 2006 If it's at speed then check that both latches on your bonnet are secure, may be it's lifting slightly and setting the light off. Used to happen to mine and seen a few threads with similar problems. Link to comment Share on other sites More sharing options...
