What to do after bpu
ChrisB
Uprated autobox. hi-stall converter.
BIG BRAKES.
Better suspension.
ie leave the engine alone till you convert to a small single :) As the only gains you'll get won't add much to your enjoyment of the car compared to the above options.
suspension was something ive considered but dont really want to lower the car just make it handle a bit better, forgot about the hi stall converter thingy, that could be a good starting point :)
Cheers for the sugestions
:innocent:
Chris, give CW a call he can do whatever you want as it's a custom suspension for YOU.
Remember that initial soop grin ? it will be back with a CW suspension.
Makes the UK spec the car is should have been out of the box.
It's one of the mods that you FEEL a big difference and you can go faster as you have more control :devil: while retaining an element of comfort for the m/way trips.
All IMO
:innocent:
Why do you say forget the Hi-stall ???????
Dude:flame Dev
ECU?
Cams?
Built gearbox?
Fuel?
All stuff to think about. I would get the ECU sorted personally. It depends how you want to do it. Some people go single on basic setups and add on the bits, others get all the suporting mods and the turbo last.
