Windscreen washer jets
psymon
There's a little rubber bung on the underside of the bonnet. Remove that and you can poke a screwdriver in and depress the little plastic tab that's preventing the jet from coming out.
It's a bit fiddly though.
I went in from the top - there is a flexible tab at each side, these sit inside the hole in the bonnet to hold it in place. 2 credit cards (one each side) slide nicely under the rubber 'washer' and allow you to push in both tabs at once.
When you pull the jet off keep a tight hold of the rubber pipe, if you let it slip inside the bonnet it could be a PITA to get back out.
Pic of a jet that's been removed to give you an idea of what I'm on about:
http://www.megaboost.co.uk/supra/mine/washers/lexus-washers-03.jpg
Speaking as a reformed offender myself, this wouldn't have anything to do with blue LED jets?
:twak:
i'm almost certain psymon is just changing his jets for some 'upgraded' ones rather than chavvy ones.
possibly to go with a carbon bonnet?
:twak:
Indeed your right, Id rather gnaw my own hand off than put chav tastic bling on my car :D :d :D :d
Cheers guys, much appreciated
