Rayman Posted October 13, 2006 Share Posted October 13, 2006 This has been on my wish list for a while before i got my car and then once i got the car wasnt sure whether i would bother or not. But now once again its back on my list of priority purchases. Ive been nowhere near needing it yet but am thinking its probably a safe bet as its a fine line between grip and slip. I was just gonna go for the basic system, im auto so launch not needed and am not too bothered about the leccy display you can have with them. Is the RLTC a pretty reliable unit? Whats all this business lately with files etc, i seen an urgent thread knocking about, has there been problems with it or the wrong files used etc? It needs to be reliable else there's no point shelling out for it. Has yours been reliable? Can it be fitted to a supe with a turbo timer and alarm without any problems? There's no extra difficulty with fitting it when other electrical items are already on your car? Any answers/comments more than welcome! Link to comment Share on other sites More sharing options...
chilli Posted October 13, 2006 Share Posted October 13, 2006 Mine has been 100% reliable so far. A doddle to set up and I highly recommend it. Its transformed my car, even just at bpu I found I really needed it! The issue with the files was just with some obscure 'smoothing' value being set when it probably should not, with it set the reading rltc gets might not be as good as it could be - this is just a configuration thing, not a hardware unreliability. don't disregard the digi adjuster, it's really nice and allows you to tweak the settings without getting the laptop out all the time... It gives nice visual feedback of what the unit is doing too, like a graph of the cuts it is making to keep traction, I like that display a lot. there are no issues with rltc and anything else, turbo timers included! Link to comment Share on other sites More sharing options...
Rayman Posted October 13, 2006 Author Share Posted October 13, 2006 don't disregard the digi adjuster, it's really nice and allows you to tweak the settings without getting the laptop out What sort of settings? Is that something you'd think i would need then, bear in mind i will be having it fitted, rather than doing it myself. Link to comment Share on other sites More sharing options...
jayssupra Posted October 13, 2006 Share Posted October 13, 2006 I'd recommend it, worth every penny. Link to comment Share on other sites More sharing options...
chilli Posted October 13, 2006 Share Posted October 13, 2006 What sort of settings? Is that something you'd think i would need then, bear in mind i will be having it fitted, rather than doing it myself. well along with the obvious slip % level it allows control over the launch control (the rev limits etc). It allows control over the main configuration settings such as the minimum slip speed, and various other settings that control the agressiveness of the traction control system. The things that allow you to fine tune it to your driving style, car and conditions. you don't need to adjust them all the time, but it can be handy and as I said, it's really nice to have visual indication of what the unit is up to. Bit like how nice it is to have a speedo and a boost guage... they all help to let you know what is going on Link to comment Share on other sites More sharing options...
Rayman Posted October 13, 2006 Author Share Posted October 13, 2006 well along with the obvious slip % level it allows control over the launch control (the rev limits etc). It allows control over the main configuration settings such as the minimum slip speed, and various other settings that control the agressiveness of the traction control system. The things that allow you to fine tune it to your driving style, car and conditions. you don't need to adjust them all the time, but it can be handy and as I said, it's really nice to have visual indication of what the unit is up to. Bit like how nice it is to have a speedo and a boost guage... they all help to let you know what is going on Argh right i see, sounds good, will look into getting the digi adjuster then. Link to comment Share on other sites More sharing options...
chilli Posted October 13, 2006 Share Posted October 13, 2006 check this out in case you're interested http://www.mkivsupra.net/vbb/showthread.php?t=85532 Link to comment Share on other sites More sharing options...
Rayman Posted October 13, 2006 Author Share Posted October 13, 2006 Yeh seen that thanks! Link to comment Share on other sites More sharing options...
Mas Posted October 13, 2006 Share Posted October 13, 2006 I think Sean is selling his 2 months old one for about £500ish , check for sale list. Edit: ooops was beaten to it again Link to comment Share on other sites More sharing options...
rob wild Posted October 13, 2006 Share Posted October 13, 2006 I installed mine no problems, install the config file and set up the abs channels etc. All was fine for a time, but unfortunately it decided to stop working well more fundamentally it stall the car whilst driving down the road! And now the car won’t start when it’s connected. So I’m the process of sorting it out! I'm sure its 1 in a 1000 but it’s not funny when you’re that one. Link to comment Share on other sites More sharing options...
mr lover Posted October 13, 2006 Share Posted October 13, 2006 I'd recommend it, worth every penny. Link to comment Share on other sites More sharing options...
Rayman Posted October 13, 2006 Author Share Posted October 13, 2006 Do you have it mR lover im presuming you do, did you fit it yourself? Link to comment Share on other sites More sharing options...
mr lover Posted October 13, 2006 Share Posted October 13, 2006 Do you have it mR lover im presuming you do, did you fit it yourself? i have got it and matt harwood fitted and set it up top job and VERY reasonable cost Link to comment Share on other sites More sharing options...
Rayman Posted October 13, 2006 Author Share Posted October 13, 2006 Link to comment Share on other sites More sharing options...
