ECK Posted October 8, 2006 Share Posted October 8, 2006 hi driving along at my usual 70 or so! i hear a loud thud and battery light came on immediatley pull over to find what the problem was? low and behold the rubber in the front pulley slit and off it came ! luckly there seems to be no other damage. is this a common problem? what is the best part to replace with? and where can i get em? the only one i can find is on envys web site for £850 quid!!!! the car is a 95 N/A! any help would be greatfully appreciated alex Link to comment Share on other sites More sharing options...
ECK Posted October 8, 2006 Author Share Posted October 8, 2006 DAMN!!! mods move to tech plz!!!! Link to comment Share on other sites More sharing options...
Kevin Huntley Posted October 8, 2006 Share Posted October 8, 2006 Yeah, seen a few go with age, mainly on the Turbo models. Best bet is to get a second hand one from a scrap yard. From memory the new ones are a couple of hundred pounds. You could fit an aftermarket version but its not really worth it unless you are running big power. Hope that helps Kevin Link to comment Share on other sites More sharing options...
supRo Posted October 8, 2006 Share Posted October 8, 2006 There was a thread recently - It's a wear and tear item that you need to keep an eye on if it' getting on a bit - You are lucky that it hasn't damaged anything else! Go for stock replacement. You must be looking at the wrong thing - Stock crank pulley is just over £200 I think Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted October 8, 2006 Share Posted October 8, 2006 Lucky it didn't make an appearance through the aluminium bonnet TBH. Link to comment Share on other sites More sharing options...
ECK Posted October 9, 2006 Author Share Posted October 9, 2006 yea i was a bit lucky eh!!! its about time my luck changed though. poss got a second hand one already will have to get a new aux belt and a rad cap too! then get it running again and check no further damage has been done!! Link to comment Share on other sites More sharing options...
