broken front crankshaft pulley.
ECK
hi
driving along at my usual 70 or so! i hear a loud thud and battery light came on immediatley pull over to find what the problem was?
low and behold the rubber in the front pulley slit and off it came !:(
luckly there seems to be no other damage.
is this a common problem?:search:
what is the best part to replace with?
and where can i get em?
the only one i can find is on envys web site for £850 quid!!!!:blink:
the car is a 95 N/A!
any help would be greatfully appreciated
alex
Yeah, seen a few go with age, mainly on the Turbo models. Best bet is to get a second hand one from a scrap yard. From memory the new ones are a couple of hundred pounds.
You could fit an aftermarket version but its not really worth it unless you are running big power.
Hope that helps
Kevin
There was a thread recently - It's a wear and tear item that you need to keep an eye on if it' getting on a bit - You are lucky that it hasn't damaged anything else!
Go for stock replacement. You must be looking at the wrong thing - Stock crank pulley is just over £200 I think
yea i was a bit lucky eh!!!
its about time my luck changed though.
poss got a second hand one already will have to get a new aux belt and a rad cap too!:rolleyes:
then get it running again and check no further damage has been done!!:blink:
