richy2jz-gte Posted April 6, 2004 Share Posted April 6, 2004 ive put a set of 18" wheels on my sup but the offsets 35mm on the back with 265 tyres they just catch the arches when you go over a speed hump. has any one here had there arches rolled on there supra if so did they roll ok? Link to comment Share on other sites More sharing options...
scooby_doo_do Posted April 6, 2004 Share Posted April 6, 2004 I've had to have my arches rolled out, as my 285 30 18's use to rub..... I think it was £25 an arch.. They basically take off your wheel and clamp a special unit to the hub.. Then they heat up the paint around your arch using a heat gun of some sort of description and then roll the unit around the arch pushing the inside lip in.. Had mine done about 4 years ago at prism motorsport in Enfield. Never had a problem since and no damage to bodywork. Craig, Link to comment Share on other sites More sharing options...
