richy2jz-gte Posted March 30, 2004 Share Posted March 30, 2004 still getting a clunking noise from the front of my car when i touch the breaks in reverse the quicker i go and put the breaks on the louder it is. ive read somewhere that it the front pads move in the calipers is this right? is it nothing to worry about? tryed all subframe bolts and there well tight. Link to comment Share on other sites More sharing options...
ardasaliah Posted March 30, 2004 Share Posted March 30, 2004 The same thing happens to me. while reversing there is a clunk noise when the break is applied. Does any on eknow ehat this is? Link to comment Share on other sites More sharing options...
Steve Cargill Posted March 30, 2004 Share Posted March 30, 2004 If you get it the first time you touch the brakes in reverse, not matter what speed you are doing or how hard you hit the pedal then that is apparently normal for UK brakes. The loose subframe bolts tend to either be a creaking when parking and/or a clunk when you stamp on the brakes. Link to comment Share on other sites More sharing options...
