clunking noise again
richy2jz-gte
still getting a clunking noise from the front of my car when i touch the breaks in reverse the quicker i go and put the breaks on the louder it is. ive read somewhere that it the front pads move in the calipers is this right? is it nothing to worry about? tryed all subframe bolts and there well tight.
If you get it the first time you touch the brakes in reverse, not matter what speed you are doing or how hard you hit the pedal then that is apparently normal for UK brakes.
The loose subframe bolts tend to either be a creaking when parking and/or a clunk when you stamp on the brakes.
