Which Injectors are a direct bolt-on ?
Supera
Which injector is recommended for the J.spec Supra w/o upgrading fuel rails etc...?
Please give me some names for 550cc, 600cc and 660cc.
And what type does the stock come as ? Top/Side Feed ? Low/High inpedance?
What is required to get, let's say SP Fuel system to work on a J.Spec Supra ?
as far as i know
JAP injectors are high impedence side feed (no resistor pack needed)
UK/US injectors are low impedence side feed, you also need the resistor pack
if you want to run low impedence injectors on a JAP car you need to buy a resistor pack. i want to go with just drop in injectors for stock rail. a few of the traders sell injectors that drop straight into JAP rail. bigger than 550cc
a lot of info is out there if you use search button. always good to get feedback though.
