Flavio Posted October 7, 2001 Share Posted October 7, 2001 What is the easiest way to raise your rev limit? What is a safe limit for a BPU++ car (FMIC, cam gears, underdrive pulleys, Greddy BCC, full catless exhaust & downpipe, boost controller)? Flavio Link to comment Share on other sites More sharing options...
Alex Posted October 8, 2001 Share Posted October 8, 2001 An aftermarket ECU is what you need...but first I would replace, at the very least, you valve train. Valves, Guides, springs, cams, cam gears. Link to comment Share on other sites More sharing options...
Guest Ash Posted October 8, 2001 Share Posted October 8, 2001 The maximum safe limit has been set by Toyota. It is not wise to raise it with a stock motor. Inertial forces increase by the square of rpm. So there is much potential for damage. Yours, J Link to comment Share on other sites More sharing options...
