Cut out problem
captainchaos
Right, I think it's either an air leak or a bad spark.
The SQV is only an issue on UK specs and VVTi's.
The fact it was fine before is also a good pointer.
I'm wondering if the ga of the denso's is much smaller than the NGK's. Are you able to measure the two plug gaps?
Does it hold full boost?
Tried switching coil packs over but still getting it only happens now and then not every time i stop happened tonight a few times so i tried driving around braking to see if it would happen but it wouldnt when i tried. When it was happening i tried putting the car into neutral to see if that would make a difference but it still happened
