Andrew Posted November 19, 2001 Share Posted November 19, 2001 I have gone back to Optimax and for some reason I has helped with my Fuel cut off problem, strange as I thought it would be the other way round Anyway I was going to use Millers to get the RON upto and around 100, but I have one question. If I add Millers will I have to stick with it? Or can I put it in now and again? These reason I ask is in case I cannot get hold of the stuff. Also I understand I need to reset my ECU, So when I pull out the fuse does the ignition need to be on? Many thanks Andrew Link to comment Share on other sites More sharing options...
Andrew Posted November 19, 2001 Author Share Posted November 19, 2001 Sorry three questions Link to comment Share on other sites More sharing options...
Guest Ash Posted November 19, 2001 Share Posted November 19, 2001 1) Depends on boost pressure. Optimax alone should be good for boost up to fuel-cut. Beyond that it's up to you. I, personally, no longer recommend boosting beyond fuel-cut without considering other factors such as additional fueling. 2) My reply in (1) refers. 3) Remove fuse with IGN off. Yours, J Link to comment Share on other sites More sharing options...
Syed Shah Posted November 20, 2001 Share Posted November 20, 2001 Get the Millers from Shop! if you want it. I don't know how good it is though so you should listen to Ash. Link to comment Share on other sites More sharing options...
Andrew Posted November 20, 2001 Author Share Posted November 20, 2001 Cheers Ash. Link to comment Share on other sites More sharing options...
