Anyone know how to install this??
Supra ST Myster
Hi
i have a manual boost controller and wondered if anyone knows how to install it? Any pics ect.. the mkiv.com isnt really how to install it i dont think as it says to do the bleeder mod first but with this i dont think you need to and just connect it up to where it says in pic?? Need to know where these pipes are.?
thanks
It goes on hose 2 in the pic. Ignore the t coming off which is just used to make the adjustment in the car (yours is all in one).
I imagine the wastegate side will go to the actuator side in the pic, but I doubt it would matter. It's just a valve that controls an escape of air from the pipe (bleed).
HTH
"MYSTER" !!
I take it you've already got a Guage fitted ??
(please don't use the bleeder without a guage !)
AND, start with the bleeder (!) NOT-bypassing first and increase
(decrease??) it slowly........
.... my one only takes ~1/2 turn-ish to 'produce' ~1.5Bar ! ! ! !
= they're not very controllable, you have to find out what each
amount of TURN will do.
Originally posted by supra TT myster
yeah thanks, i have a guage, and was going to start off with it still with the same bar reading then do a run and adjust a tad then do a run and so on till i get up to 1.2bar.
Have you still got any of your cats in place?
:thumbs:
No both cats out and with my other old exhaust cat back that i had, which was two pipes then going back into one and joining into the back box that i have advertised on the for sale section i was getting 1.2-1.3 bar, but since replacing the cat back section for another one as one of the pipes from the old system had a whole in it i am now only hitting 0.8-0.9 bar, but im a bit confused as the cat back that i replaced it with is a singel pipe, which is larger than the old system pipes 2.75" and the tail pipe is 4.5" it seems to be such a restriction?? It is also very quiet, when i first switched my engine on i thought it wasnt running thats how quiet it is!
this is the description...
Tanabe Hyper Medallion Exhaust
Full cat back system, x2 stainless boxes and i think aluminiumised mild steel rather than stainless pipework.
70mm diameter pipework and 120mm tip.
Jasma rated, so its not much louder than stock if both cats are still in.
It is second hand but in very good condition..
make sense now??
