parking sensor spraying
paul ashton
I put sensors on my red Supe - havent got round to painting them yet though. Looking at mine, they have a silicon band around them, presumably where the sensor bit actually is, so the outside edge is plastic, then the silicon, then the plastic centre. I reckon you should be able to spray them if you mask 'em off properly. You can buy a paint on liquid latex masking solution, my mate uses it for fancy airbrushing. You should be able to dab this stuff into the gap with a small brush, then peel it off after you've painted the plastic.
(Note: I bear no responsibility for any chaos and destruction that may occur during this procedure)
I've bought some I haven't had fitted yet, and the company who sold them to me suggest that prior to fitting you mount them in cardboard and give them a couple of coats of spray paint, so I reckon you sould be fine spraying them either way.
