Think this is bad :(
GazzaGSi
Carrying on from this thread: http://www.mkivsupra.net/vbb/showthread.php?t=63752
I fitted a set of new plugs today - just plugs as my lead set hadn't turned up. All plugs seemed reasonable in cylinders 1 - 5. Removed the final one - number 6 and came across this (see pic)
Fitted the new plugs and it starts and runs fine but how come number 6 cylinder spark plug was covered in oil? It isnt thick or sticky, just normal.
Will strip it down again tomorrow and do a compression test.
Pic:
All new plugs were gapped today at 1.1mm which is in the plug faqs.
My rocker is leaking towards the back of the engine (noticeable on the side of the engine) which could explain the oil possibly? I think this is the reason behind my problem due to the oil build up so the plug wasnt firing correctly.
Seems to be running fine now though. Headgasket is going to be done too in 2 weeks when it goes in for the NA/T conversion.
Fingers crossed :)
(And no cloning lol!)
Thanks for your help/opinions guys.
And to be honest, Im really pleased with myself that I have fixed it and had the courage to do it. Looked quite daunting at first with how the N/A engine is with the throttle etc going over the top of the engine and having to remove it and the hoses etc.
All happy again :D:D
Guest gzaerojon
Looks more like it has been puddled in the plug hole rather than from the cylinder.
:yeahthat:
i think you might be reading too much into it, original fault sounds like plugs (now fixed) check you rocker cover gasket for any oil leaks, could be leaking and running into the plug hole
Edit: just read all other posts... i sound like a parrot :)
