Justin Posted April 2, 2006 Share Posted April 2, 2006 Not because I'm a chavvy lout but I need to for warming up my drag tyres at Santa Pod etc. I have tried a few times on quiet roads but haven't been able to do one. I have ordered a line lock kit but not fitted it yet. I have however seen people burnout fine in autos without line locks. Don't get it:( I have a 3800 hi stall TC and over 500bhp (dynoed) When I floor the throttle from a stand still the engine just revs up then drops right back down then up then down and the wheels don't move (this is without any brakes). Is that normal? If I'm rolling first then I can manage to spin the wheels a bit but veer off out of control towards the hedge Any tips for a 5 second burnout from standing in an auto? Link to comment Share on other sites More sharing options...
Pig Posted April 2, 2006 Share Posted April 2, 2006 Power braking, e.g. hold brake and accelarator. Fries your gear box oil though! Link to comment Share on other sites More sharing options...
lockys96 Posted April 2, 2006 Share Posted April 2, 2006 umm, auto? Link to comment Share on other sites More sharing options...
terribleturner Posted April 2, 2006 Share Posted April 2, 2006 Justin i find the best and easiest is to hold the brake down (Not all the way) and gentle apply some accelaration until your moving forward slowly then at the same time more accelerator and the brake to the floor. Link to comment Share on other sites More sharing options...
Justin Posted April 2, 2006 Author Share Posted April 2, 2006 Justin i find the best and easiest is to hold the brake down (Not all the way) and gentle apply some accelaration until your moving forward slowly then at the same time more accelerator and the brake to the floor. Ta James. Will try that. Link to comment Share on other sites More sharing options...
Ian R Posted April 2, 2006 Share Posted April 2, 2006 I used to do them on standard setup as the guys above have said one major factor is to switch tranction control off. I normally drop it in first for good measure as well Link to comment Share on other sites More sharing options...
Justin Posted April 3, 2006 Author Share Posted April 3, 2006 I used to do them on standard setup as the guys above have said one major factor is to switch tranction control off. I normally drop it in first for good measure as well Yup done that Ian. Dyou just floor it straight off? Link to comment Share on other sites More sharing options...
theo sz 3.0 Posted April 3, 2006 Share Posted April 3, 2006 i tried doing a burn out and i coulnt do it ether i would say manuel is a lot easier to do it. Link to comment Share on other sites More sharing options...
dangerous brain Posted April 3, 2006 Share Posted April 3, 2006 If its factory trac can't it still cut in unless you remove the trac fuse??? Link to comment Share on other sites More sharing options...
Lucifer Posted April 3, 2006 Share Posted April 3, 2006 If its factory trac can't it still cut in unless you remove the trac fuse??? Correct. Link to comment Share on other sites More sharing options...
Justin Posted April 3, 2006 Author Share Posted April 3, 2006 If its factory trac can't it still cut in unless you remove the trac fuse??? Hmmm dunno? I usually race with the fuse out so will try doing the 'road test' that way too. Good point though DB. Might buy a trac removal jobby too as with a hi stall it is a case of all or nothing really. Link to comment Share on other sites More sharing options...
Ian R Posted April 3, 2006 Share Posted April 3, 2006 Yup done that Ian. Dyou just floor it straight off? Nope I put foot on brake lightly then gradually increase the throttle once the wheels start to spin I increase the revs at a more rapid rate. Don't know if this makes a difference but I have a LSD Link to comment Share on other sites More sharing options...
JohnK Posted April 4, 2006 Share Posted April 4, 2006 umm, auto? You know, those things that go faster down a drag strip than a manual. Link to comment Share on other sites More sharing options...
theo sz 3.0 Posted April 4, 2006 Share Posted April 4, 2006 realy? Link to comment Share on other sites More sharing options...
JohnK Posted April 4, 2006 Share Posted April 4, 2006 Do a search, especially on supra forums. Link to comment Share on other sites More sharing options...
stt Posted April 4, 2006 Share Posted April 4, 2006 i tried doing a burn out and i coulnt do it ether i would say manuel is a lot easier to do it. I should say so! Link to comment Share on other sites More sharing options...
Supra-Dupra Posted April 4, 2006 Share Posted April 4, 2006 Traction control off, and boot to the floor for a couple of secs does it for me, aint exactly hard. Link to comment Share on other sites More sharing options...
Justin Posted April 4, 2006 Author Share Posted April 4, 2006 Traction control off, and boot to the floor for a couple of secs does it for me, aint exactly hard. Well it is in my car otherwise I wouldn't be posting. As I said without brakes with trac off and flooring it the revs just hop up and down without any impulsion from the drive axle. Link to comment Share on other sites More sharing options...
Justin Posted April 4, 2006 Author Share Posted April 4, 2006 I should say so! Awesome. That's what I'm talking about! Link to comment Share on other sites More sharing options...
Rich Posted April 4, 2006 Share Posted April 4, 2006 Awesome. That's what I'm talking about! wait till you get your line/lock fitted youll have no probs then justin:) Link to comment Share on other sites More sharing options...
MONKEYmark Posted April 4, 2006 Share Posted April 4, 2006 sounds like what happend to my tc could it be faulty? my old 3800 used to do that.to do burnout with no line lock turn off stock tc and racelogic.i pulled the trac fuse in fuse box next to battery. hold foot on front brake,put into first and start reving car till it starts doing a burnout then move into second should do a burnout easy. but to be honest sounds like faulty tc? with line lock hold front brake put in 1st rev slowly then press line lock button and take foot off front brake and keeping line lock button in will hold car on spot.then release button and drive out of water box. Link to comment Share on other sites More sharing options...
Darragh Posted April 4, 2006 Share Posted April 4, 2006 haha i even had the bosses auto mercedes smoking the back tyres it is so easy to do Link to comment Share on other sites More sharing options...
Justin Posted April 5, 2006 Author Share Posted April 5, 2006 sounds like what happend to my tc could it be faulty? my old 3800 used to do that.to do burnout with no line lock turn off stock tc and racelogic.i pulled the trac fuse in fuse box next to battery. hold foot on front brake,put into first and start reving car till it starts doing a burnout then move into second should do a burnout easy. but to be honest sounds like faulty tc? with line lock hold front brake put in 1st rev slowly then press line lock button and take foot off front brake and keeping line lock button in will hold car on spot.then release button and drive out of water box. That was another reason for posting. I was concerned something was not right hardware wise. What exactly was the fault with your TC Mark? Didn't have a shard of loose metal in it or something? Could be the Blitz ECU I have also. Link to comment Share on other sites More sharing options...
Justin Posted April 7, 2006 Author Share Posted April 7, 2006 OK so I found somewhere to practise tonight and hey presto I did one! I feel like I did when I was seven and just learned how to do skids on my tomahawk:d What I did differently: 1. Less brake pedal pressure 2. Less throttle and less quickly 3. Used a road that wasn't so grippy Still getting the strange up and down rev thing sometimes though? Link to comment Share on other sites More sharing options...
MONKEYmark Posted April 7, 2006 Share Posted April 7, 2006 Still getting the strange up and down rev thing sometimes though? thats what my old one did you tried holding to say 3k revs and would drop off and go back up and drop off and back up new tc and everything was fine. they have a high failure rate on supra forums Link to comment Share on other sites More sharing options...
