Suspension "Knocking"
Patters
Hi Folks (again!)
While I've got your attention, need some more advice.  I've been having problems with my front suspension.  At first I thought it could be the wishbones, checked all the bushes, they all seem ok.  Got me brother to hang out the window a few days back while going over some speed humps, and he reckons its coming from the top of the suspension. Could it be bump stops? Or maybe the dampers? Any thoughts?
Cheers
Patters
Guest Martin F
You need to check that the cam adjusting bolts are torqued up correctly.
This is such a common problem that i would check these before doing anything else. They are the two on the inside of the lower wishbone, going through the wishbone and into the chassis.
The torque setting for both bolts is 166ft\lb.
