afennell Posted March 22, 2006 Share Posted March 22, 2006 I was just abou to fit my 550c injectors to run with the T61, when the clutch started to slip under high boost. I'm confused to what clutch to fit. I will hopefully be over 500bhp and would like to know what people use. Some poeple say the standard cluch will be fine, i think these cost about £260. Or the upgraded clutches start at £350, suggested for mlight tunning. Why would you pay the extra if the standard one works fine? Thanks for your help. Link to comment Share on other sites More sharing options...
Kopite Posted March 22, 2006 Share Posted March 22, 2006 It's the torque as well though dude, i'd definately go for an uprated one. I've spoke to people i know who just went BPU and found their stock clutch died soon after. RPS one's are common, i'm selling a RPS Sports Street clutch but there's already a buyer waiting. Give Gaz at Envy a ring and he'll sort you out. Others to consider are Southbend and Tilton if you want good ones. Link to comment Share on other sites More sharing options...
afennell Posted March 22, 2006 Author Share Posted March 22, 2006 Thanks Mate, what are the peddle movement like Link to comment Share on other sites More sharing options...
Kopite Posted March 22, 2006 Share Posted March 22, 2006 The Street clutch was the same as stock i thought, the Max im getting with a sprung hub will be stiffer but it's still not meant to be aleg breaker. Had no problems so far with the car being a daily driver Link to comment Share on other sites More sharing options...
afennell Posted March 22, 2006 Author Share Posted March 22, 2006 why are you selling rps one Link to comment Share on other sites More sharing options...
Kopite Posted March 22, 2006 Share Posted March 22, 2006 Gone for the medium sized single (probs 650rhhp with X amount of torque), Super Street wouldn't cope Link to comment Share on other sites More sharing options...
sarjo Posted March 22, 2006 Share Posted March 22, 2006 I was just abou to fit my 550c injectors to run with the T61, when the clutch started to slip under high boost. I'm confused to what clutch to fit. I will hopefully be over 500bhp and would like to know what people use. Some poeple say the standard cluch will be fine, i think these cost about £260. Or the upgraded clutches start at £350, suggested for mlight tunning. Why would you pay the extra if the standard one works fine? Thanks for your help. For an extra 90 quid I'd go the extra. Link to comment Share on other sites More sharing options...
uk-rich Posted March 22, 2006 Share Posted March 22, 2006 centreforce are pretty good, thats what i have, copes with PHR 2+ running quite high boost Link to comment Share on other sites More sharing options...
afennell Posted March 22, 2006 Author Share Posted March 22, 2006 is this the one you suggest http://www.envyperformance.com/index.cfm?fuseaction=product.display&Product_ID=1303 Gone for the medium sized single (probs 650rhhp with X amount of torque), Super Street wouldn't cope Link to comment Share on other sites More sharing options...
Gord R Posted March 22, 2006 Share Posted March 22, 2006 I have a TRD uprated single plate...just been resurfaced...also am able to supply both single plate std or paddle clutchs from ACT... Link to comment Share on other sites More sharing options...
afennell Posted March 23, 2006 Author Share Posted March 23, 2006 An more info on the trd clutch, is it a trd fly wheel? I have a TRD uprated single plate...just been resurfaced...also am able to supply both single plate std or paddle clutchs from ACT... Link to comment Share on other sites More sharing options...
Underworld Posted March 23, 2006 Share Posted March 23, 2006 I read something on another supra forum about "its an absolute must to upgrade your clutch for 6 speed manual bpu". I was a bit confused by this, as I wouldnt have thought that the stock clutch would have been ok considering you only have a bit extra bhp. Link to comment Share on other sites More sharing options...
afennell Posted March 23, 2006 Author Share Posted March 23, 2006 What power would you say the standard clutch can handle? Link to comment Share on other sites More sharing options...
Kopite Posted March 23, 2006 Share Posted March 23, 2006 is this the one you suggest http://www.envyperformance.com/index.cfm?fuseaction=product.display&Product_ID=1303 They might of been renamed, could be the one but for better advice, speak to Gaz on 01670 823333 - depends on what you want out of the car, driving style and how much bhp/torque you might go for in the future. Like i didn't think i'd ever go single when i got the Sports clutch, now i'm having to get rid of it for the Max! Doh! Link to comment Share on other sites More sharing options...
Guest Terry S Posted March 23, 2006 Share Posted March 23, 2006 I read something on another supra forum about "its an absolute must to upgrade your clutch for 6 speed manual bpu". I was a bit confused by this, as I wouldnt have thought that the stock clutch would have been ok considering you only have a bit extra bhp. funny, the stock clutch held my 523 ft/lb of torque well. AFAIK, the single plate TRD clutch is a stock plate with an uprated pressure plate ( muted to be RPS). Link to comment Share on other sites More sharing options...
supratoy Posted March 23, 2006 Share Posted March 23, 2006 I just had the rps sports puck and flywheel fitted. I was worried that it was going to be a pain in the rear but has turned out to be very easy on the left leg. Link to comment Share on other sites More sharing options...
afennell Posted March 23, 2006 Author Share Posted March 23, 2006 My stock clutch lasted a year after the single was fitted but only running 1 bar. The car has done nearly 80k, probably has more to do with it. Link to comment Share on other sites More sharing options...
afennell Posted March 23, 2006 Author Share Posted March 23, 2006 How much judder do you get with the rps clutch when in traffic? Link to comment Share on other sites More sharing options...
foodfreak Posted March 23, 2006 Share Posted March 23, 2006 I had the RPS with a 6 puck centre plate, was a bugger in heavy traffic, used to shudder & squeal like a pig RPS street max I have now is much better:thumbs: John Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted March 23, 2006 Share Posted March 23, 2006 I have the TRD single clutch, had it for about 2 years, it starts to slip (just) after a bit of a sesh on a dyno, on the road it is OK at present, but will need to be uprated when a single gets put on... Link to comment Share on other sites More sharing options...
afennell Posted March 23, 2006 Author Share Posted March 23, 2006 I had the RPS with a 6 puck centre plate, was a bugger in heavy traffic, used to shudder & squeal like a pig RPS street max I have now is much better:thumbs: John how much did you pay for the street max. Sounds a bit over kill for my car but really dont want the judder. What was the pedal like? Link to comment Share on other sites More sharing options...
afennell Posted March 24, 2006 Author Share Posted March 24, 2006 I just had the rps sports puck and flywheel fitted. I was worried that it was going to be a pain in the rear but has turned out to be very easy on the left leg. was there any judder in traffic? was it the 6 puck one? Link to comment Share on other sites More sharing options...
