Spark plug gap questions.
tbourner
OK so I'm trying to do my plugs, but exactly what gap should I be using and how precise does it need to be?
Alex's spark plug FAQ says:
TT @ upto 1bar
NGK - BCPR7ES (3330) - gap 0.9mm
NGK - BKR7E (6097) - gap 0.9mm
NGK - Iridium - BKR6EIX or BKR7EIX - leave gap alone
Denso Platinum - PK20R11 - gap 0.8mm
Denso Iridium - IK22 - leave gap alone
TT/hybrids @ upto 1.3bar
NGK - BCPR7ES (3330) - gap 0.7mm
NGK - BKR7E (6097) - gap 0.7mm
NGK - BKR8E - gap to 0.7mm
NGK - BCPR8ES (3330) - gap 0.7mm
NGK Iridium - BKR7EIX - leave gap alone
NGK Iridium - BKR8EIX - leave gap alone
Denso Platinum - PK20R8 - gap 0.7mm
Denso Iridium - IK24 - leave gap alone
But that's a big change, 0.7mm - 0.9mm!!! And I'm running 1.15 Bar so should I do what I did last time and do it to 32 thou (0.8mm)?
How do I know what my gap should be without keep taking the plugs out and making it ever smaller until it misfires!!! I'm still new so this still takes an hour each time!!! :rolleyes:
Also, how precise does it need to be? Can one plug be 0.8mm and the next be 0.75mm?
And how tight should the feeler guage be in the gap? When I was misfiring I couldn't get the 0.8mm feeler in!!! Had to wiggle it about a bit. Should it go in smooth and easy or should there be some resistance?
And this is the easiest DIY job - I can make a meal out of anything!! :D
Well I had too small a gap before, hence I had problems all over Christmas with poor idle. I regapped the 2 small gaps and it was ok.
Now I'm having a similar problem and I'm just going to change the plugs completely but unsure what gap to choose.
