Suprash Posted October 26, 2003 Share Posted October 26, 2003 Guys, thought I would put up my dyno sheets for everyone to strip apart and tell me whats what. Couple of things to note is I done 2 dynos first on a true twin setup (red and green ), then I done 2 runs on sequential (blue and pink ). So anything I should/could do to improve things, its taken me all day just to fugure out what it all says. On the day I was happy, I know you can only takethese figures with a pinch of salt, but looking forward to doing some mods and then comparing again. Link to comment Share on other sites More sharing options...
Suprash Posted October 26, 2003 Author Share Posted October 26, 2003 Next... Link to comment Share on other sites More sharing options...
Suprash Posted October 26, 2003 Author Share Posted October 26, 2003 And last... Link to comment Share on other sites More sharing options...
Suprash Posted October 26, 2003 Author Share Posted October 26, 2003 Whoops, missed no2.... Link to comment Share on other sites More sharing options...
Suprash Posted October 26, 2003 Author Share Posted October 26, 2003 Just looking at the boost graphs, it says I hit 14psi at 1.3, I thought 1.2 was around 18psi, the max you should go to. And also why does it drop of to around 1.0, shouldnt it hold at maximum ???? Anyway, I'll await someone that knows.... Link to comment Share on other sites More sharing options...
lovatt Posted October 26, 2003 Share Posted October 26, 2003 my boost drops off at the end, pete told me it was because of the bleedvalve i have Link to comment Share on other sites More sharing options...
osso Posted October 26, 2003 Share Posted October 26, 2003 How the heck did they manage to measure the boost? did they put additional sensors in the engine bay? if they did, it would be interesting to know where they took the measurements. You will probably find that the reason why the boost drops of to around 1.0 after reaching a peak of 1.3 is because the Waste gate spring is only designed to hold at 1.0 bar any excess pressure would be released... but then i could be talking bollox, after all, im only a software engineer! Link to comment Share on other sites More sharing options...
lovatt Posted October 26, 2003 Share Posted October 26, 2003 i saw pete take a pipe off the plenum (sp ?) chamber and connect a pipe from the dyno to it, i think this monitored the boost, but i am only guessing. it did monitor the boost though as i have a graph showing it Link to comment Share on other sites More sharing options...
dude Posted October 26, 2003 Share Posted October 26, 2003 Originally posted by osso How the heck did they manage to measure the boost? did they put additional sensors in the engine bay? if they did, it would be interesting to know where they took the measurements. You will probably find that the reason why the boost drops of to around 1.0 after reaching a peak of 1.3 is because the Waste gate spring is only designed to hold at 1.0 bar any excess pressure would be released... but then i could be talking bollox, after all, im only a software engineer! You have become obsessed with wastegates James , explain my 1.5 bar holding all the way then Dude:flame Dev Link to comment Share on other sites More sharing options...
osso Posted October 27, 2003 Share Posted October 27, 2003 Thats easy dude, you've welded your wastegate shut! lol.. so how else would you explain a drop off from 1.3 to 1.0 apart from the possibility of the BOV leaking I suppose i was talking bollox, afterall, you can get upto 1.4 + bar removing the both CATS. I always thought that wastegates were sprung shut with a spring that had a pressure limit, maybe not. Link to comment Share on other sites More sharing options...
Mark Ayling Posted October 27, 2003 Share Posted October 27, 2003 Ash, you don't really use liquorice Rizla do you??? (sorry, that was a bit of a hijack!) Link to comment Share on other sites More sharing options...
eyefi Posted October 27, 2003 Share Posted October 27, 2003 they rnt liquorice, they're lightweight, the king of rizzla's Link to comment Share on other sites More sharing options...
Mark Ayling Posted October 27, 2003 Share Posted October 27, 2003 Originally posted by eyefi they rnt liquorice, they're lightweight, the king of rizzla's I thought the blue ones were liquorice, my lightweight Rizlas are silver, but then I did get them in France... Link to comment Share on other sites More sharing options...
millhouse Posted October 27, 2003 Share Posted October 27, 2003 Originally posted by Mark Ayling I thought the blue ones were liquorice, my lightweight Rizlas are silver, but then I did get them in France... Blue Rizlas are for lightweights thats why Ash uses them Link to comment Share on other sites More sharing options...
JamesG Posted October 27, 2003 Share Posted October 27, 2003 Originally posted by osso Thats easy dude, you've welded your wastegate shut! lol.. so how else would you explain a drop off from 1.3 to 1.0 apart from the possibility of the BOV leaking Could it be a boost spike up to 1.3 bar? It looks like the pressure was rising very quickly up to that point. James. Link to comment Share on other sites More sharing options...
Suprash Posted October 28, 2003 Author Share Posted October 28, 2003 Guys, good replies, I havent had a chance to read properly as Im just logging on quick, will reply to whats said when Im in work tonight, but any comments from people on what they think I should be doing would be great, and Mark and Kev, so you like my scanning.... Link to comment Share on other sites More sharing options...
Patrick_Devlin Posted October 28, 2003 Share Posted October 28, 2003 Good scans Ash. Interesting to see the difference between the true twin and sequential set up Link to comment Share on other sites More sharing options...
Suprash Posted October 28, 2003 Author Share Posted October 28, 2003 Originally posted by Patrick_Devlin Good scans Ash. Interesting to see the difference between the true twin and sequential set up What did you get Patrick ???? Link to comment Share on other sites More sharing options...
Patrick_Devlin Posted October 28, 2003 Share Posted October 28, 2003 I got 367 rhhp and 366 ft/lb torque. Was very very happy with that!!! Link to comment Share on other sites More sharing options...
pulse Posted October 28, 2003 Share Posted October 28, 2003 Blue are the traditional thin ones.. silver are the new, even thinner ones Sorry, no idea about the dyno stuff, but I know my papers -p Link to comment Share on other sites More sharing options...
millhouse Posted October 28, 2003 Share Posted October 28, 2003 Originally posted by pulse Sorry, no idea about the dyno stuff, but I know my papers me too Link to comment Share on other sites More sharing options...
Suprash Posted October 29, 2003 Author Share Posted October 29, 2003 So for all the people in know on the board, anybody know why my boost drops off, does my fueling look ok, and any answers to my earlier 1.3b - 14psi question.....???? Link to comment Share on other sites More sharing options...
Suprash Posted October 29, 2003 Author Share Posted October 29, 2003 Originally posted by Patrick_Devlin I got 367 rhhp and 366 ft/lb torque. Was very very happy with that!!! Nice one mate, I got less rwhp but more torque ??? Link to comment Share on other sites More sharing options...
Patrick_Devlin Posted October 29, 2003 Share Posted October 29, 2003 Ash, I'm PMing CW about my fuelling issues at the moment. As usual he's being exceptionally helpful Link to comment Share on other sites More sharing options...
Suprash Posted October 29, 2003 Author Share Posted October 29, 2003 Yeah think I do the same, get my sheets to someone that knows, as theres not many opinions around here..... Link to comment Share on other sites More sharing options...
