Tricky-Ricky Posted March 8, 2006 Share Posted March 8, 2006 Are there any easy to get at that you can get about six to eight wires through? and if so where? Link to comment Share on other sites More sharing options...
whitesupratt Posted March 8, 2006 Share Posted March 8, 2006 By the throttle in the driver footwell, big yellow grommet already with some loom going through it. Iv just put my boost hose through it. Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted March 8, 2006 Author Share Posted March 8, 2006 Thanks! can you get at it from both sides? Link to comment Share on other sites More sharing options...
whitesupratt Posted March 8, 2006 Share Posted March 8, 2006 yep, wire coat hanger method is the best, I would highley recommend going from the footwell outwards. i ended up on my back, with my drivers seat as flat as it would go upside down in the footwell doing this. will be your easiest option tho Link to comment Share on other sites More sharing options...
SupraHuman Posted March 8, 2006 Share Posted March 8, 2006 I think the yellow grommit by the throttle runs inside the wheel arch when exiting on engine side.I does on mine anyway. Link to comment Share on other sites More sharing options...
whitesupratt Posted March 8, 2006 Share Posted March 8, 2006 mine went into the engine bay no probs, or it wouldnt have been anygood for a boost gauge hose. Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted March 8, 2006 Author Share Posted March 8, 2006 My problem will be that i want to run four thermocouples through from the engine side, as they have delicate right angle bends in them that can't be threaded through! Link to comment Share on other sites More sharing options...
whitesupratt Posted March 8, 2006 Share Posted March 8, 2006 Well that grommet comes out totaly, so easily, and back in! or pull it out, put them through, THEN put the grommet back in. Link to comment Share on other sites More sharing options...
