Where is the keyless entry ECU?
randy
There is a small blue connector by the fuse box in the drivers footwell, this has about 16 wires to it - I don't have the wire colours to hand, I ended up tracing them back to the switch :) but I'll check tonight and let you know which the lock/unlock wires are.
lock : Red/white with silver band
unlock : Green/red with silver band
these are the ones that come from the switch on the drivers door, it looks like these will lock/unlock the car but if you lock the car with the key then these won't unlock it - but I may be wrong there :D
