Supera Posted October 5, 2003 Share Posted October 5, 2003 Got a new battery "Panasonic" and everything came back to life weeeeeeeeeew, unfortunately my radio/cd/cassette didn't work same goes for the horn Anyone know what's causing all this PITA ? Link to comment Share on other sites More sharing options...
Timwildman Posted October 5, 2003 Share Posted October 5, 2003 you checked the fuse? Link to comment Share on other sites More sharing options...
Supera Posted October 5, 2003 Author Share Posted October 5, 2003 Yea they all seemed to be alright! could it be the wiring ? Link to comment Share on other sites More sharing options...
toyotasuprauk Posted October 5, 2003 Share Posted October 5, 2003 Is there a separate wiring terminal that connects to the battery's positive that hasn't been reconnected? Link to comment Share on other sites More sharing options...
Supera Posted October 5, 2003 Author Share Posted October 5, 2003 It's been connected properly! and still none of these 2 wanna work Link to comment Share on other sites More sharing options...
Timwildman Posted October 5, 2003 Share Posted October 5, 2003 I dont mean to be teach you to suck eggs but, have you checked the hidden fuses in the drivers r/h kick panel. If all is well here. well you will need to see if power is getting to the horn and radio. Tester needed Or to simply test the horn conect 2 wires to the horn direct from the battery. this will let you know if it's f***** the radio is a lot harder to get to need to dismantle the dash for that. Oh did they work before the battery change?? Link to comment Share on other sites More sharing options...
Supera Posted October 5, 2003 Author Share Posted October 5, 2003 It wasn't working in the first place I guess it's a little bit late now to go and check it out again at 11pm Where's this ? drivers r/h kick panel Please post a pic I feel sleepy and I'll check it out tomorrow Originally posted by Timwildman but, have you checked the hidden fuses in the drivers r/h kick panel. If all is well here. well you will need to see if power is getting to the horn and radio. Tester needed Or to simply test the horn conect 2 wires to the horn direct from the battery. this will let you know if it's f***** the radio is a lot harder to get to need to dismantle the dash for that. Oh did they work before the battery change?? Link to comment Share on other sites More sharing options...
Timwildman Posted October 5, 2003 Share Posted October 5, 2003 there is 1 radio fuse in the kick panel, hope it helps. Blury but you get the idea: Link to comment Share on other sites More sharing options...
Supera Posted October 6, 2003 Author Share Posted October 6, 2003 Thanx Man! I never bothered to look down there, but will do today Link to comment Share on other sites More sharing options...
Supera Posted October 6, 2003 Author Share Posted October 6, 2003 My headunit has been abused by the previous owner I need to get a new one, cd wasn't working only the fm + cassette and the speakers must be changed too Link to comment Share on other sites More sharing options...
