Mark Ayling Posted October 3, 2003 Share Posted October 3, 2003 ....is probably not something I want to do for long, right? I guess that now the weather's cooling down I'm boosting higher, I thought the car felt quicker today and when I looked over at the AVC-R it was showing a peak hold of 1.45 So am I right in assuming I need to get a restrictor ring to limit boost slightly? TIA Link to comment Share on other sites More sharing options...
SkyJawa Posted October 3, 2003 Share Posted October 3, 2003 Blimey! I got up to 1.35 last week and sent for a ring from Chris to drop it to 1.1-1.2. Cost was £15 + £2 P&P cheque payable to Chris. Tell him what you hit and what you want and he'll do his best! Mines dropped to a fraction under 1.0 now, as Chris said its hard to get it exactly right, but its also warmer this week than last so not a true test - tomorrow is looking interesting though (eg cold morning 5 celsius), and I'm running on the rollers too If its still too low Chris said its simply a case of whipping the ring back out again and enlarging the diameter of the hole by about 2mm. Fits inbetween the 2nd cat section and the rear pipework! Job done! Link to comment Share on other sites More sharing options...
Mark Ayling Posted October 3, 2003 Author Share Posted October 3, 2003 Cheers Neil - actually, after I started this thread I then read your "where did you locate your restrictor ring" thread which pretty much answered my question! I'll give Chris a shout shortly Link to comment Share on other sites More sharing options...
SkyJawa Posted October 4, 2003 Share Posted October 4, 2003 lol! No probs! Link to comment Share on other sites More sharing options...
Supra ST Myster Posted October 4, 2003 Share Posted October 4, 2003 Could you get the restrictor ring, which will take down the boost to say 1.0bar and stop it from spiking, then get a boost controller and set it to 1.2bar and be safe that way, or just changing the ring a much cheaper option?? Link to comment Share on other sites More sharing options...
TLicense Posted October 4, 2003 Share Posted October 4, 2003 I was told that the Blitz DSBC ID III could limit boost anyway. I sthis correct? Would you still need a restrictor ring? Cheers Link to comment Share on other sites More sharing options...
SkyJawa Posted October 4, 2003 Share Posted October 4, 2003 TT myster - yes you can do it that way, but changing the ring is the cheapest option. however, when the warmer weather comes the boost will drop again, so you'd be likely to need a controller to raise it again then.............. I've heard that Leon can reduce boost with that Blitz controller, don't know the details though............ Link to comment Share on other sites More sharing options...
GavinL Posted October 4, 2003 Share Posted October 4, 2003 Originally posted by HISUPE TT myster - yes you can do it that way, but changing the ring is the cheapest option. however, when the warmer weather comes the boost will drop again, so you'd be likely to need a controller to raise it again then.............. I've heard that Leon can reduce boost with that Blitz controller, don't know the details though............ With some Blitz boost controllers, you would need to check with him. Link to comment Share on other sites More sharing options...
SkyJawa Posted October 4, 2003 Share Posted October 4, 2003 Yeah - Gavin is right, its only some, can't remember if its the DSBC or the SBC-ID etc......... Link to comment Share on other sites More sharing options...
