dark stranger Posted February 15, 2006 Share Posted February 15, 2006 do all dump valves make a loud hiss...or are there ones that make a chirping type noise???.......sorry for the dumb question ...but would really like to know please:) Link to comment Share on other sites More sharing options...
BURT Posted February 15, 2006 Share Posted February 15, 2006 dump valves make a hiising noise as you said but blow-off vavles dfo make more of a chirping sound... if you are gonna get one fella, best to get a HKS SSQV.. ya dont wanna sound like an rs turbo everytime ya change gear...lol Link to comment Share on other sites More sharing options...
dark stranger Posted February 15, 2006 Author Share Posted February 15, 2006 so does that eliminate the hissing noise....and does it replace the dump valve?? Link to comment Share on other sites More sharing options...
tbourner Posted February 15, 2006 Share Posted February 15, 2006 Dump valves are BOVs, just different names. I'm guessing you're talking about turbo chatter when you say the chirping noise - some singles you can run with no BOV and the pressure goes back through the turbo; stalling it and giving a chatter noise. a dump valve or BOV will usually give a different kind of noise depending on the size and shape of the flute that the air comes out of. Link to comment Share on other sites More sharing options...
BURT Posted February 15, 2006 Share Posted February 15, 2006 yes fella, it does eliminate the hissing to a degree and will replace you recurc' blow off valve, the blow off valve is also better for your tubbies than a dump-vale, as it only dumps pressure thats the tubbies dont need, dump valves however do just that, they dump all pressure between gear change, wich mean your tubbs do have to work a little harder to spool up again Link to comment Share on other sites More sharing options...
BURT Posted February 15, 2006 Share Posted February 15, 2006 yes fella, it does eliminate the hissing to a degree and will replace you recurc' blow off valve, the blow off valve is also better for your tubbies than a dump-vale, as it only dumps pressure thats the tubbies dont need, dump valves however do just that, they dump all pressure between gear change, wich mean your tubbs do have to work a little harder to spool up again this is what i was told by the guys at sumopower when i bought mine.... if i am wrong however i stand corrected. Link to comment Share on other sites More sharing options...
JohnA Posted February 15, 2006 Share Posted February 15, 2006 ... the blow off valve is also better for your tubbies than a dump-vale, as it only dumps pressure thats the tubbies dont need, dump valves however do just that, they dump all pressure between gear change, wich mean your tubbs do have to work a little harder to spool up again HUH?! Link to comment Share on other sites More sharing options...
tbourner Posted February 15, 2006 Share Posted February 15, 2006 this is what i was told by the guys at sumopower when i bought mine.... if i am wrong however i stand corrected. I'm pretty sure it's one of those 'regular misconception' things that they are different. http://www.mkivsupra.net/vbb/showthread.php?t=35947 I may be wrong though - we need an expert really. Link to comment Share on other sites More sharing options...
BURT Posted February 15, 2006 Share Posted February 15, 2006 HUH?! care to elaberate? Link to comment Share on other sites More sharing options...
JohnA Posted February 15, 2006 Share Posted February 15, 2006 Maybe that salesman should care to elaborate. I'm always intrigued by theories and explanations cocked up within milliseconds in order to close a sale... Link to comment Share on other sites More sharing options...
Ian W Posted February 15, 2006 Share Posted February 15, 2006 it does make quite a convincing story though JohnA, you have to admit. certainly for someone like myself who knows not a lot about tubbies, bov's etc would more than likely believe every word of it. wouldn't mind knowing the facts though if there are any experts in here? ps you getting rid of the n/a then dark? Link to comment Share on other sites More sharing options...
mikeyb10supra Posted February 15, 2006 Share Posted February 15, 2006 There is no difference, it releives compression surge/excess boost, and thats it....does'nt matter if its a BOV, Dump, air release or any other name they care to call it, they can be made to do different things, but all have the same function Link to comment Share on other sites More sharing options...
dark stranger Posted February 15, 2006 Author Share Posted February 15, 2006 so whats the chattery noise some have....is it when there is no dumo valve?? Link to comment Share on other sites More sharing options...
mikeyb10supra Posted February 15, 2006 Share Posted February 15, 2006 are you talking about a highly tuned single car or a stock twin car?? Link to comment Share on other sites More sharing options...
dark stranger Posted February 15, 2006 Author Share Posted February 15, 2006 stock mate:) Link to comment Share on other sites More sharing options...
Alex Posted February 15, 2006 Share Posted February 15, 2006 Dump Valves and BOV's are the same. But you can have Push or Pull type. And you can have recirculating or "to atmosphere" BOV's. Recirculation BOV's are best used with MAF based Supra's and are quieter. Atmospherics are best on MAP based Supras these are loud. The only DV/BOV I know of that chirps is the BAILEY one, it did it on my 200SX....however, for all I know the unit was faulty and I was actually getting turbo chatter Not running a bov and getting the noise you want through stalling the turbo's is a VERY BAD IDEA!!!! Don't even contemplate it. Too much stress, only race cars should do it imo. Link to comment Share on other sites More sharing options...
dark stranger Posted February 15, 2006 Author Share Posted February 15, 2006 apparently the ssqv with a siver fin makes a different noise anyone got one???...soundclip?? Link to comment Share on other sites More sharing options...
mikeyb10supra Posted February 15, 2006 Share Posted February 15, 2006 it makes more of a chirp sound than the others do....its more high pitched and more shrill go onto www.blowoffvalves.com Link to comment Share on other sites More sharing options...
