Vaughany Posted September 21, 2003 Share Posted September 21, 2003 Can someone help me with this, I have recently had my front Brake Pads changed. I noticed that I was getting a clunking/knocking noise when I was braking. This noise only occurred when the car was going forward and was absent when is in reverse. I was informed from a BBS Member that the Brake Pad Retaining Clips may have been put on upside down. I have changed these around and the noise only happens in reverse now. Is this as it should be? The clips are now on with the V shape part of the clip at the top of the caliper with the point of the V pointing out and the top clip hooked over the the top caliper pin. Is this how it should be or have I put this on wrong. Could someone please explain to me the correct setup of how the Brake Pad Retaining clips should go in. Unfortunately I did not change the pads myself so I didnt see the original setup. Youre help in this would be most appreciated, should there be a noise when braking in reverse or is there still a problem. Cheers for the help Link to comment Share on other sites More sharing options...
Guest Terry S Posted September 21, 2003 Share Posted September 21, 2003 I'd drop in and see Leon. He is only in Bletchley. 01908 367100 sorry for the short answer I am on the way out. Link to comment Share on other sites More sharing options...
Vaughany Posted September 21, 2003 Author Share Posted September 21, 2003 I am off to see him tomorrow but I thought if I could solve the problem then I would save both mine and his time. Cheers anyway Link to comment Share on other sites More sharing options...
supra dan Posted September 21, 2003 Share Posted September 21, 2003 it would be good if you could post the solution, ive got the same thing with mine, swapped to uks but never seen how the clips are supposed to fit Link to comment Share on other sites More sharing options...
