Help!!!!! Problem with 96 Supra
Guest Paul86510
Guest Paul86510
I have a toyota supra and it is a non-turbo with a turbonetics turbo upgrade converting it to a turbo. My problem- i had an accident and since the accident the car has not run right. There were codes thrown and they were missfire codes, too lean code, oxygen sensor 1 malfunction,and oxygen sensor 1 running slow during testing. I replaced the spark plugs, cause all 6 of them were fouled out, and that fixed the missfires. I also replaced the fuel filter, and both oxygen sensor 1 and oxygen sensor 2 and it did nothing for me. I will start the car and it runs fine at idle,but when i slowly start pushing down the accelerater climbing from 1000 rpm to 1500 rpm it does fine but as soon as I hit 2000 rpm it drops down below 2000 rpm and if i sit there and keep the accelerater at the same place it took to reach 2000 rpm it will repeatidaly drop and go back up and drop below 2000 rpm. If I drive the car it does the same thing, but when I drive it will go over 2000 rpm and drive but it acts like its not getting gas and will slow down and then kick back in and go, but i replaced all fuel related parts, also put in lucus fuel injector cleaner and that didnt work either. I need help, and any you can supply will be greatly appriciated. thank you
Guest Paul86510
What is AFR? Just body work damaged, yes running piggyback ecu, also check engine light came on and threw a code saying it was too lean... I'm lost!!! HELP!!
