Guest kidzik007 Posted December 29, 2005 Share Posted December 29, 2005 Greetings! I need some info on a brake swap I've seen in some MKI GS300. I've seen the TT MKIV brakes on some JZS147 and 161's. If anybody has info on how this swap is done and any info on it it would be greatly appreciated. By the way, because my budget doesen't allow me, a JZS147 was the closest thing to a MKIV I could afford Thank you. Link to comment Share on other sites More sharing options...
garethr Posted December 29, 2005 Share Posted December 29, 2005 Straight swap, I believe. This is also a popular mod on the Soarer. The main problem is making sure that your wheels will clear the big 4-piston front calipers. Anything which will fit a UK-spec Supra TT will do. An alternative is a pair of alloy 4-piston front calipers from a series 2 LS400. They are a lot lighter but apparently slightly less powerful. PS You should find useful information on http://www.clublexus.com/forums http://www.lextreme.com/suprabrakeupgrade.html Link to comment Share on other sites More sharing options...
