Is it true that the 1jz 550cc High Impedence Injectors...
Guest begone
....will work with the JDM Fuel Rail and be an easy drop in? This would allow JDM owners to upgrade injectors and it be a direct swap. Is this true or not? Thanks.
Correct Jake, the 1JZ comes with 380cc side feed low imp injectors...
Begone must be talking about aftermarket ones and if so there are 550cc side feed low imps he could use so he would not need a resistor pack. There are no 'drop in' 550 high imp injectors for the 1jz.
