wez_p Posted December 14, 2005 Share Posted December 14, 2005 i'm on a mission to find out what the vibration is that i get when my auto is sat in 'drive' with my foot on the brake it's also sometimes noticeable when allowing the car to 'idle' it's way forward if you know what i mean, when it's a slight incline, such as when i'm putting it in the garage if i pop it out into neutral or park then it's fine again which is leading me to believe it may be something to do with the auto box / torque converter the idle speed doesn't seem to affect it much, and i've also fitted an earthing kit in case it was some kind of electrical drain issue or bad earth has anyone ever heard of resetting or re-calibrating a torque converter? i'm a bit puzzled really on how to solve this one thanks, Wes Link to comment Share on other sites More sharing options...
hadyn Posted December 14, 2005 Share Posted December 14, 2005 time for a fluid change? Link to comment Share on other sites More sharing options...
wez_p Posted December 15, 2005 Author Share Posted December 15, 2005 time for a fluid change? definitely a possibility, cheers Hadyn i've checked the fluid level & it seems fine but it's got to be worth a try Link to comment Share on other sites More sharing options...
JohnA Posted December 15, 2005 Share Posted December 15, 2005 You checked the level with the engine running, right? Link to comment Share on other sites More sharing options...
wez_p Posted December 15, 2005 Author Share Posted December 15, 2005 You checked the level with the engine running, right? yes but this was at least 6 months ago now so will do it again to be sure Link to comment Share on other sites More sharing options...
JohnA Posted December 15, 2005 Share Posted December 15, 2005 ...I was just checking that you haven't got problems from overfilling it, quite an easy thing to happen if you hadn't had an auto before (like myself, I first thought it was like manual boxes) Link to comment Share on other sites More sharing options...
