dandan Posted July 21, 2003 Share Posted July 21, 2003 Hi all, Can anyone give me any pointers or pitfalls to watch out for doing the following. I have Tein HA rear susp set up and wish to remove the damper and spring assembly to have a good look at the condition of it, and the top mount. As with most owners i have no manual (YET) and didn't wanna just jump straight in. Do i need to compress the spring to carry out the removal. Any input is greatly appreciated as are any scanned pages of relevant documents......hehe Thanks in advance guys...and gals Dan Link to comment Share on other sites More sharing options...
eyefi Posted July 21, 2003 Share Posted July 21, 2003 this should b of some use. Link to comment Share on other sites More sharing options...
dandan Posted July 22, 2003 Author Share Posted July 22, 2003 cheers eyefi, thanks a lot. saving the pages now on my mega cr@p dial up connection! if you didn't already know i've just bought my supe after about a month of discussion and haggling. http://www.mkivsupra.net/vbb/showthread.php?s=&threadid=10517 Link to comment Share on other sites More sharing options...
eyefi Posted July 22, 2003 Share Posted July 22, 2003 yeah, it looks mint. personally i like to b sure of my buy too, which is ok if there's not loads of other folk looking at it. did u have any competion while looking over it? it might b worth having a search over on supraforums.com just to see if there's any other useful tips. they're always taking their cars to bits Link to comment Share on other sites More sharing options...
dandan Posted July 22, 2003 Author Share Posted July 22, 2003 apparently one chap genuinely thought it was too fast and subsequently wanted an auto instead, another couldn't get a decent insurance quote for centre of london. all in all he waited about 5 weeks for me to decide!! seriously nice chap. i think he wanted to sell it to me as i showed a lot of genuine interest, a fair bit of knowledge and he wanted it to go to a good home. Link to comment Share on other sites More sharing options...
Need4Speed Posted July 23, 2003 Share Posted July 23, 2003 Rear unit has three little (10mm spanner) nuts at the top an one big bolt (19mm spanner) through the suspension arm. About a 10 minute job to remove/replace once the wheel's off. Link to comment Share on other sites More sharing options...
dandan Posted July 24, 2003 Author Share Posted July 24, 2003 aha, thanks john. no need to compress the spring then?? not 100% if thetein is same as stock installation wise....hope so Link to comment Share on other sites More sharing options...
Need4Speed Posted July 24, 2003 Share Posted July 24, 2003 No need to compress the spring to remove the whole unit. Whether you need to compress to remove the top mount, I don't know as I've not got standard springs. Link to comment Share on other sites More sharing options...
Jake Posted July 27, 2003 Share Posted July 27, 2003 Originally posted by John Packham Rear unit has three little (10mm spanner) nuts at the top an one big bolt (19mm spanner) through the suspension arm. About a 10 minute job to remove/replace once the wheel's off. I'm trying to do this right now but once the bottom bolt has been removed the shock extends to longer than it was before and now won't come out. Looks like I might have to remove the brake caliper, I can't see how it's possible to remove the strut with the caliper in place. Link to comment Share on other sites More sharing options...
Jake Posted July 27, 2003 Share Posted July 27, 2003 Originally posted by dunk657 I'm trying to do this right now but once the bottom bolt has been removed the shock extends to longer than it was before and now won't come out. Looks like I might have to remove the brake caliper, I can't see how it's possible to remove the strut with the caliper in place. yeah came off ok once the caliper was removed. Still had to have somebody else to push the hub etc down so as to lift the shock over it but got there in the end. Certainly not a 10min job though. Link to comment Share on other sites More sharing options...
Need4Speed Posted July 27, 2003 Share Posted July 27, 2003 Apply some weight (your foot) to the disc/hub then swing out the top mount. You can then lift off the rear mounting from the suspension arm and it comes out easily - well it does on mine. I was serious about the 10 minutes - I've taken both out in 30 including jacking up the car and removing the wheels. But not the first time I did it:( Link to comment Share on other sites More sharing options...
Jake Posted July 27, 2003 Share Posted July 27, 2003 Originally posted by John Packham Apply some weight (your foot) to the disc/hub then swing out the top mount. You can then lift off the rear mounting from the suspension arm and it comes out easily - well it does on mine. I was serious about the 10 minutes - I've taken both out in 30 including jacking up the car and removing the wheels. But not the first time I did it:( Top out first eh? I never tried that. I'll remember that for next time! Cheers Link to comment Share on other sites More sharing options...
Need4Speed Posted August 24, 2003 Share Posted August 24, 2003 Just done this again; the trick is to jack up both sides even if you only want to take one out. This will unload the ARB and make the job much easier. ps Sorry the three top nuts are a 12mm spanner, not a 10mm. Link to comment Share on other sites More sharing options...
dandan Posted August 24, 2003 Author Share Posted August 24, 2003 thanks john, i still haven't tackled the job yet. almost definately doing it tommorrow afternoon. thanks again. am i right in thinking: undo top three 12mm nuts, undo lower 19mm nut, push hub down, pull/lever top out first and hey presto?? Link to comment Share on other sites More sharing options...
Jake Posted August 24, 2003 Share Posted August 24, 2003 Originally posted by dandan thanks john, i still haven't tackled the job yet. almost definately doing it tommorrow afternoon. thanks again. am i right in thinking: undo top three 12mm nuts, undo lower 19mm nut, push hub down, pull/lever top out first and hey presto?? yes as long as both rear wheels are clear of the ground Link to comment Share on other sites More sharing options...
dandan Posted August 24, 2003 Author Share Posted August 24, 2003 thanks a lot, i'll keep you posted Link to comment Share on other sites More sharing options...
