Ian W Posted December 10, 2005 Share Posted December 10, 2005 morning guys any idea whether it's likely to be a bulb or a fuse that's caused the lights to go out behind my temp and fan speed dials? cheers Link to comment Share on other sites More sharing options...
Guru Posted December 10, 2005 Share Posted December 10, 2005 Dunno but mine has gone on my temp one too! Link to comment Share on other sites More sharing options...
Mcgoo Posted December 10, 2005 Share Posted December 10, 2005 Mine suffers from the same fault, but a well placed "tap" on the side cures it. Ive had it out, but every time i do it works fine, just something loose. it is very easy to get to.. just a gentle lever with a screw driver around the trim and it just unclips. Dont think it would be a fuse as normally more than one thing stops working. Link to comment Share on other sites More sharing options...
Kev.O Posted December 10, 2005 Share Posted December 10, 2005 Mine suffers from the same fault, but a well placed "tap" on the side cures it. Ive had it out, but every time i do it works fine, just something loose. it is very easy to get to.. just a gentle lever with a screw driver around the trim and it just unclips. Dont think it would be a fuse as normally more than one thing stops working. If my memory serves me correct there should also be a screw which you need to undo. Here's a step by step guide from Heckler's website! http://www.internetwork.org.uk/dashrem.htm Link to comment Share on other sites More sharing options...
piehound Posted December 10, 2005 Share Posted December 10, 2005 i swapped all mine last week its like blackpool but dont unplug your airbag or you need to reset the light Link to comment Share on other sites More sharing options...
piehound Posted December 10, 2005 Share Posted December 10, 2005 here ya go all done i got the last lights i needed from an auto electrician for £1 each he only had 6 left , lucky me note the airbag light lol i unplugged it grrrrrrrrrrrr:blush: but its ok now Link to comment Share on other sites More sharing options...
Ian W Posted December 10, 2005 Author Share Posted December 10, 2005 will be removing the dash to sort out the aerial anyway so will have a looksy then... luckily for me, i don't have an airbag so don't need to worry about that lol Link to comment Share on other sites More sharing options...
