DaveM Posted December 3, 2005 Share Posted December 3, 2005 While recently fitting an HID headlamp kit my turbo timer decided to stop working. I am assuming that I have blown a fuse somewhere (I managed to blow one of the headlamp fuses at the same time) and am trying to find where the fuse would be. I currently have the dashboard apart and it looks as if the Turbo timer has it's own adapter that plugs into the large multiplug just behind the ignition switch. Everything else seems to be working fine. The turbo timer loom does not have it's own fuse built into the adapter so I am assuming that it must use one of the standard Toyota fuses. Does anyone have any idea which one and where I might find it? Link to comment Share on other sites More sharing options...
SupraHuman Posted December 3, 2005 Share Posted December 3, 2005 have you checked the fuses behind the kick panel in the foot well(driver side)?I assume you've checked fuses in the engine bay? Link to comment Share on other sites More sharing options...
DaveM Posted December 3, 2005 Author Share Posted December 3, 2005 I've checked the fuses in the engine compartment and am currently trying to remove the fuses one by one from the fuse box in the drivers footwell. Can't find a bleeding torch when you need one so it looks like I'm going to have to put it all back together again and pop down to B & Q to buy a torch before I can progress any further. Link to comment Share on other sites More sharing options...
