Soop Dogg Posted January 26, 2002 Share Posted January 26, 2002 Just got my RLTC and was wandering if anyone has got any advice on fitting it. Wiring diagrams would be a great help re the ABS unit and generally any help would be greatly appreciated. E-mail me directly if you happen to have any pic's/diagrams etc. Thanks in anticipation! Link to comment Share on other sites More sharing options...
Guest Martin F Posted January 26, 2002 Share Posted January 26, 2002 Brian you need to look here :- http://www.mkiv.com/manual/index.html For the wiring diagrams. The ABS unit is a pig to do as it is under the stereo and the wires are extremely short. Best tip i can give you is to make sure you remove the passenger seat before even starting The last job is to load up a decent file of settings and dump what's in there. Speak to Phil Wall about an appropriate file. Good Luck Link to comment Share on other sites More sharing options...
Matt Harwood Posted January 26, 2002 Share Posted January 26, 2002 Brian, do you have the info you require? I recieved the pin out diagram from racelogic yesterday for a J-apec if it's any help I can forward it to you. Link to comment Share on other sites More sharing options...
Phil Wall Posted January 26, 2002 Share Posted January 26, 2002 If anyone is fitting RLTC to their car and would like a copy of the notes I made when I fitted mine. Drop me an e-mial and I will attach a copy by return. I also have a range of data files you can load in if you have a lap top. Link to comment Share on other sites More sharing options...
