antno Posted November 2, 2024 Share Posted November 2, 2024 (edited) Ive decided to sell my supra because it isn't getting driven as much as it should. The car hasn't been too much trouble over the years and I believe it to be fairly honest. Ideally I would like it to go to a member so I've decided to list it here first. Make: Toyota Model: Supra RZ original v160 6speed manual Year: 1996 Facelift: no Mileage: 62,426 miles TOTAL this might go up a little Imported with 83092km (51630miles) then covered to miles, now showing 93888 MOT remaining: September 2025 Service history: Serviced by myself. Oil and filter every year. Cam belt done within the last 500miles along with oil, brake and clutch fluid. Always used millers CFS 10/50 and genuine Toyota filters. Gates belts and genuine Toyota tensioners and pulleys. There have been quite a few bits fitted over the years. Rear wheel bearings, rebuilt turbos etc, I have a lot of receipts from Toyota and various places. All have not a lot miles on them. Car's location: Daventry Imported by Jurgen (JM-Imports LTD) in 2011. Where they carried out an underseal. The car has never seen a salted road and the car was started every 2 weeks in the winter. Modifications: BPU. Veilside exhaust, HKS F-Con silver, ARC front mount intercooler that has been fully ducted so all the air goes through it. Grade 7 NGK spark plugs and bigger gss342 fuel pump to support the other mods. Ati fluid crank damper. Chris Wilson fast road clutch, it's a new genuine Toyota cover with a slightly heavier diaphragm. It also can be run safely without the F-con if you are worried it’s not really needed for this low amount of engine mods. Chris Wilson fast road pads for the UK spec brakes and genuine Toyota discs. Motul brake fluid with Goodridge braided lines. discs and pads will be less than 1000miles on them Chris Wilson fast road dampers. Progressive Eibach springs on the rear and non progressive on the front. Chris Wilson did the ride height and geometry setup. Large B03B differential with a Kaaz fitted. Work Emotion CR Kai 18x8.5 and 18x9.5 both +30 All three Genuine TRD gauges. TRD Spoiler. (I do have a 040 white original spoiler that will be sold with the car, will need a flick of paint though). Bad bits: The car isn't show grade and has all the usual problems with 28 year old Japanese paint when you look closely. It has had paint work. Isn't necessarily good or bad but the carpet inside has been cut to accommodate, I'm guessing, a Cusco roll cage. The type that dodges the dashboard. It’s never bothered me as the quality of the carpet is really good and if you are planning on fitting a cage it is a benefit. PRICE £45k Open to offers. Not really in any rush and would rather see it go to a good home. Edited April 14 by antno (see edit history) Link to comment Share on other sites More sharing options...
antno Posted November 2, 2024 Author Share Posted November 2, 2024 1 Link to comment Share on other sites More sharing options...
antno Posted April 14 Author Share Posted April 14 Sold Link to comment Share on other sites More sharing options...
