mrboomberang Posted October 8, 2017 Share Posted October 8, 2017 Needing some help after having my bumper and two new headlights fitted about a month ago there is a gap between the headlights and bumper at the front Link to comment Share on other sites More sharing options...
Mika Posted October 8, 2017 Share Posted October 8, 2017 (edited) You need to loose both side front fender/ wing fastener nuts (2x10mm nuts inside of the bumper) and push the front bumper sides backwards. After you have adjusted the front bumper cover in correct location, gaps will disapear under of the headlight edge seals. 53121E nuts in the picture: https://www.google.fi/search?client=firefox-b&dcr=0&biw=1680&bih=941&tbm=isch&sa=1&q=toyota+supra+bumper+side+mounting&oq=toyota+supra+bumper+side+mounting&gs_l=psy-ab.3...35529.46903.0.47074.22.17.5.0.0.0.95.1269.17.17.0....0...1.1.64.psy-ab..0.0.0....0.dBZ30JMi2Fo#imgrc=Ibt_MLWVEsL43M: Edited October 8, 2017 by Mika (see edit history) Link to comment Share on other sites More sharing options...
achagor Posted October 8, 2017 Share Posted October 8, 2017 Do you have the clips located under the headlights, part number 52115A and 52116A see in above link, should solve the problem mate! Link to comment Share on other sites More sharing options...
mrboomberang Posted October 8, 2017 Author Share Posted October 8, 2017 Do you have the clips located under the headlights, part number 52115A and 52116A see in above link, should solve the problem mate!I don't have these clips will call Mr t tomorrow not sure if the guy who done the job maybe broke them and kept quiet about it[emoji848] Link to comment Share on other sites More sharing options...
