Soonto_HAS_soop Posted September 21, 2005 Share Posted September 21, 2005 Can anyone with the Air Con Diagnostics sheets please post them here, or email PM me so that I can get a copy emailed to me? Matt H, I know you said that you had them somewhere, but I never got round to getting a copy off of you. Ta.. Link to comment Share on other sites More sharing options...
toyotasuprauk Posted September 21, 2005 Share Posted September 21, 2005 I've got it, whats your e-mail address then? Need to attach as its a pdf. Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted September 21, 2005 Author Share Posted September 21, 2005 PM'd Link to comment Share on other sites More sharing options...
DamanC Posted September 22, 2005 Share Posted September 22, 2005 excuse my ignorance but what is Air Con Diagnostics? Link to comment Share on other sites More sharing options...
toyotasuprauk Posted September 22, 2005 Share Posted September 22, 2005 If you have a problem with your air con, ie it doesnt work. You can press a few buttons at the same time on the dash and certain dash lights flash. You then tally these lights up with the diagnostics to find out where your problem is. Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted September 22, 2005 Author Share Posted September 22, 2005 Yep, mine is fault with the pressure switch. Looks like I'll be delving behind my glovebox soon to see if the voltage is as it should be. If not, who was it that was taking PM's for breaking a TT? Link to comment Share on other sites More sharing options...
toyotasuprauk Posted September 22, 2005 Share Posted September 22, 2005 Soonto I fixed I A/C a long time ago so I dont 100% remember but when the gas gets low, to prevent damage to the air con system the pressure switch cuts in to stop it being used. It doesnt always mean the pressure switch needs replacing but like I say I dont really remember so check over the diagnostics carefully before buying any new parts. Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted September 22, 2005 Author Share Posted September 22, 2005 I had it leak tested and regassed like 9 months ago after it wasn't working, so it cannot be that (I hope). Although it really wasn't that cold when he had finished refilling it with Gas, so maybe something else was wrong with it. I do know that the pump doesn't kick in, so I will do the tests first before buying anything. TBH, I might even rip it all out as I haven't used it for this summer anyway - much prefer to have the windows down and listen to the exhaust. Just looking and it says that I need to test the A/C amplifier, as well as possibly testing the pressure sensor in the engine bay. Does anyone have a picture of the pressure sensor and it's location within the engine bay? Link to comment Share on other sites More sharing options...
