Matt Harwood Posted April 10, 2003 Share Posted April 10, 2003 When I first installed my RLTC, the main power wire was under tension behind the kickwell panel. If a passenger pushed hard on the floor, they could make the car cut out! They don't fail safe. Link to comment Share on other sites More sharing options...
Adam W Posted April 10, 2003 Share Posted April 10, 2003 Matt, I was trying to find out if a passenger brake pedal had been installed behind there as well . . . Link to comment Share on other sites More sharing options...
Matt Harwood Posted April 10, 2003 Share Posted April 10, 2003 You found it a couple of times! Link to comment Share on other sites More sharing options...
Guest Martin F Posted April 10, 2003 Share Posted April 10, 2003 Originally posted by SimonB You can always unplug it and plug the connectors together if it blew up though (Assuming you had a screwdriver with you of course...) Assuming the connectors have been used. Link to comment Share on other sites More sharing options...
